Question about Kyocera Office Equipment & Supplies
KM-5050 printing black pages
Our printer randomly prints out solid black pages. Sometimes it's the first few pages of a print job, other times it could be a few pages in the middle. This happens when printing, copying, and with incoming faxes. Our maintenance company has come out and cleaned it several days in a row. There must be something else going on. Suggestions?
Mix-it-up
  • 832 Answers
SOURCE: Cancelling Incoming Faxes in Memory
see manual (can be download from homepage www.brother.com). If you are a victim of spam faxes you better buy a new mfc with a pc-fax-incoming-transmission function (e.g. mfc 440cn etc.) This will give you the opportunity to have a look at the faxes on the screen first and then to decide which one should be printed.
Posted on Jan 15, 2008
leroyal
  • 2120 Answers
SOURCE: stapling from the print mode
Yes, look in the printer properties in control panel to set this option before you print.
Posted on Jan 02, 2009
Rebgagnon
  • 382 Answers
SOURCE: CANCELLING AN INCOMING FAX JOB
SHould be able to power down unit and remove power cord for few minutes. That should erase the Stored memory that it has been set into.
Posted on Jan 29, 2009
SOURCE: Smartbase MP390 Printer - error ##345
canon smartbase mp390 error ##345 check printer can anyone help me
Posted on Feb 08, 2009
  • 70 Answers
SOURCE: can't print a complete print job without problems
There may just be some type of configuration issue going on if you don't have a drive installed in this printer. If there is no drive installed the printer drivers may be functioning as if there's one present which results in this error. I'm providing you with a few possible solutions as it is more difficult to pinpoint an issue when you don't have access to the device.
If it is a configuration issue you can try these steps:
1. Mopier mode should be disabled.
Right-click printer then click properties.
You should find a device settings tab...scroll down to mopier
mode and make sure it's disabled.
2. Printer Hard Disk should be disabled.
Go to the Device Settings tab...scroll down to Printer Hard Disk
3. If you had to disable one or both features then the very last thing that you want to do is try printing a multiple page document to see if this worked.
If you check these two settings and find that both the mopier mode and printer hard disk are disabled then you can try this:
Click this sentence to follow the link to HP's driver and software page for the 4600 series printers. Find your operating system in the list and click on it. This will bring you to the page with drivers, firmware, and additional software provided for your printer type. Try downloading the drivers (unless you have the installation CD) and reinstalling the printer. Also, make sure that you have the latest Service Pack installed for your operating system. If you're using Windows XP then the latest Service Pack is 3.
Hope this helps. I work with HP printers and sometimes I have to try more than one solution before I find the right fix.
Please share your experience by rating this solution and thanks for using Fixya.
Posted on Mar 28, 2009
How to set system to print in color
KM-3050/4050/505 is a pure Black & White MFP
Oct 18, 2014 | Kyocera Tk-717Km-3050/4050/5050
My printer only prints black
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 08, 2013 | Konica Minolta MAGICOLOR 7300EN LASERPR...
White line in print
If a printer does not get a steady rate of print jobs it will perform self maintenance to preserve the print system. These maintenance cycles will vary since they are dependent on overall usage. If a printer is not connected to a power source for an extended period of time, you may have to run a clean or deep clean of the printhead to recover.
Feb 05, 2012 | Lexmark X83 All-In-One InkJet Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
May 09, 2011 | Lexmark X7350 All-In-One InkJet Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Printing backwards mid-job?
the ram in your kyocera is going bad... there is also the possibility (if you have an internal hard drive) that your internal hard drive needs to be reformatted... consult a service tech in your area...
thehre is also the off chance that its a power problem... get a good power conditioner or surge protector and see if that helps before calling the tech...
Jan 23, 2009 | Kyocera CS-2050 Black and White Copier
44 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
