Question about RCA HD61LPW165 61" Projection HDTV
50" RCA DLP color wheel replacement procedure
I have a 50" RCA DLP with the model number HD50LPW62AYX2. I need to change the color wheel but cannot find any how-to's when I google it. Although, there seems to be a lot of info including how-to videos for Samsungs. I believe the color wheel part number I need is RCA 267888. Any information or pictures (depicting the location of the color wheel) you can give me would be greatly appreicated! Thank You!
  • 1 more comment
  • Anonymous Feb 14, 2009
    we have the same problem. the color wheel is on national back order, cannot find it anywhere.
  • mikepo Mar 22, 2009
    i have the same problem. if you found anything on this could you post it please. i would like to replace it myself.
  • Anonymous Mar 29, 2009
    Same problem here too!!!! Has anyone found a color wheel yet? thanks
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
Posted on Dec 06, 2009
Do you get to the color wheel through the front or back?
Posted on Dec 02, 2009
  • raw334 Dec 17, 2009
    I bought a motor, but the noise was worse after I put the new motor on. Eventually, I found that the rotor (attached to the color wheel) had a bad spot inside it that was rubbing on the stator. The bad spot turned out to be chrome that was coming off, and a dimple was created, causing the rub. I scraped the spot of chrome off, and it is now working fine (at least for now).
  • 4 Answers
Here is a company selling the RCA 267888 color wheel:
http://www.partstore.com/Part/Thomson/RCA/267888.aspx?s=froogle
Working on the RCA SCENIUM 50"DLP HDTV HD50LPW164 was easy. Access to the color wheel was not from the back. Taking off the screen revealed a plastic cover. Underneath, the wheel was easy to locate and remove.
FYI Clearly, the tiny motor that spins the wheel is not up to the task. Too many fail within 2 years, some less.
The bearing is just a bronze bushing. Once it has worn down, the wheel can vibrate and the squealing begins.
The motor is made by Delta. A company I have emailed who tell me I could buy from them. In the meantime I bought a motor from a company here in the US.
The motor looks exactly the same BUT how on earth one changes over the glass color wheel to the new motor is a mystery. I have emailed the company, TSM Inc. to ask them if they have the info. By selling the motor separately, I was led to believe it was possible to change over the color wheel.
Here is the motor I purchased:
http://www.tristatemodule.com/storename/rivervalleyelectronicparts/ViewDept-253886.aspx
Scroll down.
Hope the info helps!
Cheers,
Dave
Posted on Apr 22, 2009
  • drumrrrr Apr 22, 2009
    Well guys,
    I just took a second look at the Tristate Module page I just posted.
    Duh, it clearly shows where to insert a screwdiver blade. With a little more effort than I expected, the new rotor popped off the stator. I cleaned the spindle on the color wheel/rotor combo and inserted in to the new stator. I gave it a firm push together and it popped into place. Voila, perfect! No play and the wheel spins perfectly.
    I'll be reinserting the color wheel unit tomorrow. A $50 fix! Can't beat that!
    Cheers guys,
    Dave
I had already bought the Delta motor from TSM before I found this site. $55 shipped, got it next day. Replacement was straightforward and fairly easy. Works great.
Posted on Jul 03, 2010
  • 718 Answers
You can get parts and help at;
http://servicemanuals.vstore.ca/
They will charge for manuals but they also give on-line tech support free!
Posted on Apr 06, 2009
    Guru:
  • 114 Answers
Hey i can pass you this link. they usually got a lot of brands
and a cool video were you can change your own color wheel..
http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel
Posted on Feb 09, 2010
I have been using lithium grease to lubricate the color wheel motor for over a year.
works great for about a month, but then have to do it again.
it''s a pain but i can do it now in under an hour , start to finish.
Posted on Jun 24, 2009
    Problem Solver:
  • 4 Answers
I know where to get refurbished and remanufactured color wheels - call this guy in Kansas at 785-214-1221. You'll be glad you did!
Posted on Mar 17, 2011
  • WrongPhoneNo Apr 01, 2011
    WRONG! My number is 785-214-1221. I DON'T KNOW ONE END OF A TELEVISION FROM ANOTHER. Whoever johnhickock is, he is dead wrong.
2 Suggested Answers
SOURCE: RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Posted on Jan 06, 2009
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 48 inch rca dlp tv that does nothing except blink green light in front and makes a loud noise no pic no sound. do i need to replace the lamp and the color wheel or juss one of them, or should i...
Hello my friend...
probably you do need to change your color wheel have you change your TV lamp?
here is a website were you can check prices they are really good not to expensive.
and yes i recommend to buy just the parts and not a new TV fix the one that you have
http://www.discount-merchant.com/Factory-Original-Lamps-Bulb-For-your-RCA-Scenium-p/rca-lamp-265866-26591-269343.htm
http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsung-cw-bp96-01579a-enc.htm
the prices may go lower depending on your TV part.
good luck.
Mar 17, 2010 | Televison & Video
WHINING SOUND
More likely it is the color wheel this set uses---it is located inside the optical engine---part number for it:
267888This part is no longer available from RCA but is available on several sites on the internet (google the part number)
The wheel will when going bad sometimes make a fan like noise or even a high pitched whine.
Check out the sites on the net that sell this for price and decide if you want to attempt to replace it or if you have to have a shop do it for you.
Let me know if you have any questions or need advice.
REGARDS, SD TECH
Oct 05, 2009 | Televison & Video
Instructions on How to change an RCA Color Wheel
You can get help at;
Apr 06, 2009 | RCA HD61LPW165 61" Projection HDTV
How to replace rca color wheel
Its fairly easy. Remove the back of the TV. You'll need torx head screwdrivers as RCA uses them exclusively on their TVs. The color wheel is mounted on the light engine to the left of the lamp assembly and has three screws holding it in place. There are also two connectors which have to be undone. You may have to transfer them from the old to the new one. On rare occassions, an alignment of the wheel speed is necessary. If that's the case, you'll need to contact an RCA authorized service center to have this done.
michtech
Feb 14, 2009 | RCA HD61LPW165 61" Projection HDTV
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
8,778 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
