Question about Cosco Alpha Omega 22-180 - with Shield
Shield reattachment i am attempting to reattach the shield to the seat and the two white clips(one for each side) i cannot figure out how they go back on near the springs, cannot find any help online via a cosco customer service help line or anything, my homeowner guide/manual is packed up somewhere in storage please find me some assistance thanks sorry for the nickname it was the 8th try all others were taken
  • 1 more comment
  • sherri66 Dec 10, 2007
    I have the same problem and I cannot find my clips to lock in place. Where can I buy new ones?
    Thanks,
    sherristjohn@msn.com
  • sandadauel Aug 30, 2008
    I need the white disc clip things also.
  • Anonymous Sep 06, 2008
    trying to reconnect the shield
Need to reattch te base
Posted on Jan 12, 2008
OK, I found my manual and have successfully removed the base, shield and harness...oh rah! Here's what the manual says, word for word for REINSTALL: IF YOU DO NOT REATTACH THE SHIELD AND HARNESS CORRECTLY, YOUR CHILD MAY COME OUT OF THE RESTRAINT IN A CRASH, RESULTING IN SERIOUS INJURY OR DEATH. NOTE: It is easier to complete all the following steps if the headrest is in the lowest position. TO REPLACE BASE: Remove bar from base and place shell onto base so it lines up securely. Starting with the rounded end, push bar compeltely through slot until it locks in place. TO REPLACE SHIELD: Lay shield upside down with the shield closest to you. Position arms over holes, align notch over keyhole, and push arms in; rotate shield over to the front of the seat. From inside shell, put locks onto ends of both arms and rotate locks clockwise to secure in place. To replace the pad, see page 15. Thread the harness ends through the slots. The harness MUST go over the metal bar in back. Reattach ends of harness to harness bracket. There were pictures but I'm a lousy artist but you should be able to get the gist of it. The locks are the little round white plastic parts with tabs sticking out to be used to twist them into place. REMOVAL OF SHIELD: TO REMOVE SHIELD: Unlock buckle. Unfasten ends of harness from harness bracket in back of seat. (Harness bracket can be looped over brace on back of car seat for storage). Adjust headrest all the way down. Rotate shield up and over back of car seat. Undo 4 fabric clips, work cover over sholder belt guides and pull cover away from side of shell so you can reach te lock. Push in on white lock, turn counterclockwise and remove. Repeat for other side. Pull arms out of holes and remove shield, pulling harness straps out othrough front of seat. You must save the shield and locks in order to use the shield with the seat in the future. The locks can be saved in the storage compartment in the base. TO REMOVE BASE: Move seat to fully reclined posiion. Push down on tab on right side of base. From the other side, start pushing on bar and pull the bar copletely out. Lift shell off base. You must save the bar in order to use the seat with the base in the future; the easiest way to do so is to replace the bar. Push the rounded end over the tab all the way across the base until it shaps in place. Hope this helps!
Posted on Oct 02, 2006
Well, I don't have a solution to getting it back on, but if you could tell me how to get the stupid thing off, I could maybe figure out how to get it back on for you. :) I can't find anything about it via Cosco either. grrrrr!
Posted on Sep 14, 2006
SOURCE:
Disconnected white cable
if it is a flat cable some of them had a little clip that would slide back allowing you to reattach the cable some do not
Jan 29, 2014 | Kodak ESP Office 2150 Wireless All-In-One...
How do I convert a Nautilus 3 in 1 carseat to the toddler position
Turn around fold bar under sit in seat facing forward and reattach all anchor points again. to change belt posiotion look on back at belts should have a clip holding the 2 belts , take off thread through a higher position and reattach and adjust. hope this helps
Nov 18, 2011 | Graco Nautilus 3-in 1 Car Seat
How to put shield back on
you must put the arms in the appropriate holes in the sides ,then with the white locking clips on the inside beneath the seat cover attached to the portion of the arm the extrudes thru the holes and turn until it locks
Sep 08, 2011 | Cosco Alpha Omega 22-180 - with Shield
I put in new cartridges and the orange light keeps blinking
If that's the access foor at the back of the printer might just be loose or unlocked. Try locking the door into place and see what happens. Or if you have a duplexer. Try these:
  1. Press the buttons on each side of the duplexer to release it. Figure 7: Press the buttons to release the duplexerc02622982.gif
  2. Remove the duplexer from the product.
  3. Reattach the duplexer. Press the buttons on each side of the duplexer, and then gently push the duplexer back into the rear of the product until it snaps firmly into place. Figure 8: Reattach the duplexerc02622983.gif
  4. Repeat the steps to reattach the duplexer if the lights remain on.
    Link: HP Deskjet 940c Printer - Blinking Lights
Feb 04, 2011 | HP DeskJet 940c InkJet Printer
How do you open a xbox 360 Halo reach edition xbox? Thanks in advance
I will provide a step by step process on how to open up or disassemble the xbox 360, the steps takes You all the way to the lens. Pleas get these instruments(Bath towel, Flat-edged screwdriver, #15 Torx screwdriver, Phillips jeweler's screwdriver, Tweezers, White glove, Compressed air) then follow the steps below:
  1. Unplug the Xbox 360's power cord and remove any cables, game controllers and USB flash drives connected to it. Place a bath towel on a table. Place the console vertically on the towel with the faceplate facing up.
  2. Grip the left top side of the faceplate and the bottom right side. Pull the left side of the faceplate to the left and the bottom right side up to remove it from the console.
  3. Rotate the console so that the vent-like holes are on either side. Insert the tip of a flat-edged screwdriver into each of the holes and lift up to release the inner clips.
  4. Place the console face down on the towel. Raise the shelf on the bottom to reveal the screws beneath it. Remove these screws with the Torx screwdriver. Return the console to an upright, horizontal position on the towel. Grip the sides of the console and pull the outer case off.
  5. Remove the screws at the back panel with the Torx screwdriver. Pull the back panel off the console. Pull the plastic inserts on either side of the console off. Remove the screws from the metal shield on the top of the console with the Torx screwdriver. Pull the metal shield off.
  6. Locate the DVD drive that is on the console. The DVD drive is a rectangular metal box with a warning sticker on the top. Remove the screws from around the drive with a Phillips jeweler's screwdriver. Lift the drive up and pull the two cables out of its back.
  7. Place the DVD drive on the towel face down. Remove the screws from the sides of the drive with the Phillips jeweler's screwdriver. Slide the case off the drive.
  8. Turn the drive over. Locate the lens assembly at the center of the drive. Remove the screws from the clip placed on the drive that is next to the spindle at the center of the lens assembly with the Phillips jeweler's screwdriver.
  9. Remove the clip. Grip the lens that is under the clip with a tweezers. Remove the lens from the lens assembly and dispose of it in the trash.
  10. Put on a white glove. Pick up an edge of the replacement lens with the hand that is wearing the white glove. Place the lens in the depression that was formerly occupied by the original lens. Rotate the lens to seat it in the depression. Place the clip back on and reattach the screws. Blow off the lens and laser assembly with a burst of compressed air.
  11. Place the back panel on, reattach the screws and return the plastic inserts to their original positions on the console. Place the outer case back on. Turn the console over and reattach the screws to the bottom. Return the console to its original location, reattach the cables, game controllers and USB flash drives to their original positions. Plug the power cord back into a wall outlet.
Hope this helped. Thank You for using FixYa!!!
Jan 26, 2011 | Microsoft Xbox 360 Halo 3 Special Edition...
Recently purchased, used Mazda 3 driver side seat belt is completely slack and will not retract. If I remove panel that is between front and back driver side doors to attempt to fix will that damage panel?...
The panel is attached with plastic clips, if you damage them replacements are available. Chances are you won"t be able to repair the belt retractor as it"s a sealed mechinism.
Jan 03, 2011 | Mazda MAZDA3 Cars & Trucks
How do you remove the cover and belts on an evenflo car seat with this number on the side 25801158?
Turn the booster seat around to the back and locate the metal splitter plate that the harness is attached to. Remove both harness straps from the splitter plate. Locate the TensionRight knob located on each side of the seat in the front by the baby’s foot area. Turn the TensionRight knob to the back as far as it will go to take up the slack on the splitter plate strap. Pull both harness straps through the seat back to the front of the seat. Remove the harness strap from both sides of the chest clip and from the buckle tongues. NOTE: Please leave the buckle tongues locked into the **** strap for storage. Remove the harness strap from the seat. NOTE: Reattach the chest clip to the harness strap so they don’t get lost. Turn the booster seat upside down and locate the metal harness anchor. Turn the metal anchor sideways and push it through the slot to the front of the seat.
Sep 08, 2010 | Evenflo Generations
I can't reattach the shield to my Alpha Omegal car seat 22-180 because I can't figure out how the white clips go onto the springs. I really need a manual.
I hope by now you have figured it out. the clips go on the inside under the seat cover. attached to the part of the arm you inserted and turn to lock. the clips don't go on the springs.
Nov 29, 2009 | Cosco Alpha Omega 22-180 - with Shield
2003 Buick. The pass side wiper stopped working,
the arm mechanism has a clip that pop off get a new clip and remove the access panel and move the arm over to the access area put the arm back into the hole socket and reattache clip , not the easiest repair but with a long pair of needle nose pliers you should have a better chance to complete repair. Some cars to access the arm the wiper motor must be disconnected and pulled out slightly then move wiper over and reattache pin arm into lever hole nstall clip.
Jul 08, 2009 | 2003 Buick Regal
Cosco Alpha Omega 22-180 - with Shield Logo
270 people viewed this question
Top Cosco Baby Gear Experts
Zarir Irani
paul
Steve Allison
Steve Allison
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
