Question about HP Deskjet D1430 InkJet Printer
Green light won't stop blinking on my hp deskjet d1430 ----just put in 2 new cartridges and paper is not jammed
  • 8 Answers
SOURCE: hp deskjet 6980 blinking lights
ok so for this situation you have to do a cold reset, and by this you have to go ahead while the printer is still power on, disconnect the power cord in back of the printer, and wait for about two minutes. power on the printer if printer still has the blinking lights then go to step 2.
step 2-after this check the printer if light are still blinking, then your going to remove all printheads, remove paper, and then unplug printer power cord from printer and also from the wall outlet, wait for 20 seconds, then power on the printer, wait for light to flash then install the printheads, put paper, and press the resume button.
*** always connect your printer to a wall outlet never to a power strip, the power strip robs some of the power from the printer***
and this should fix the problem if it doesnt then the carriage might me malfunctioning . hp recently did a recall on some printer with the 6940 and some of the 6980, that the carriage broken.
Hope this help!
Posted on Mar 06, 2008
efs_perpends
  • 1996 Answers
SOURCE: My HP 5550 Deskjet printer
Please go the this link at the HP online support site and follow the instructions given for your error lights to adjust the printer clutch.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 29, 2009
laxmankumar
  • 191 Answers
SOURCE: HP Deskjet D2360, blinking green light,
Click Here
and follow the instructions to resolve this issue.
Posted on May 25, 2009
cene765
  • 787 Answers
SOURCE: hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Posted on Nov 04, 2009
  • 7 Answers
SOURCE: HP deskjet 3845 will not feed paper to print
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Posted on Jul 14, 2010
My HP Deskjet 1120Cxi fails to print normal document and test printing. My computer operating system is window XP
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
It just started blinking and says the printer is offline
If it says printer is offline, it usually means your printer is not connected to the PC. Blinking printer light means there is a problem with the printer (usually paper jam) or with the ink. Check the ink cartridge. Take the cartridge out and put it back in. Make sure you also check the USB cable that goes from your printer to the PC, take it out and put it back in. Also, try to turn off the printer, take it out of the power outlet for 30 seconds and put it back in. If you have a power strip, don't use it, try plugging it directly to the power outlet on the wall and turn it back on.
Nov 09, 2009 | HP Deskjet D1430 InkJet Printer
Hp 5550 deskjet not printing
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
Flashing yellow light not allowing me to print
just put in new cartridges in paper full,no jams
Jul 13, 2009 | HP Deskjet D4160 InkJet Photo Printer
Blinking green light
Clear the paper jam, or replace the ink cartridge. Possible causes are the paper jam or ink cartridge. The other solution is to disconnect the power from your printer and reconnect it. Hope this helps!
Oct 22, 2008 | HP Deskjet 3845 InkJet Printer
Hp5740 printer
There are 2 lights, one green and one orange.
If the green one blinks, there's no problem (As says on the manual it blinks cuz is preparin to print)
If the Orange one blinks There are 2 problems:
a) Paper Jam
b) No Paper or Paper Sensor Trapped.
Just keep reading th Owner's Manual and Say somethign if there are no solution.
Manuals Here
Aug 13, 2008 | HP DeskJet 5740 InkJet Photo Printer
Blinking lite on a hp deskjet 970cxi printer
2 reasons.
1)paper jam internally. chk carefully.
2)paper sensor problem.
just moove a paper in tray &tell me green lite is glow/not?
Aug 11, 2008 | HP Office Equipment & Supplies
HP Deskjet D1430 InkJet Printer Logo
213 people viewed this question
Seeker5211
Seeker5211
