Question about Hoover Washing Machines
Error code E08 on Hoover dyn 8164d. What is it pls?
Error code E08 appeared at end of wash. Can't get rid of it. Machine under 1 year old. What is it pls?
2 Suggested Answers
  • 6277 Answers
SOURCE: my hoover dyn 8164d washing
Hoover's 'e03' states 'drain timeout'- probably a blocked filter or even jammed drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 07, 2011
My hoover washing machine model dyn d8p has a code error of ao3/t know what is wrong ..its new and just used then 3 month now but it was not drying well and showing that error code
if it is 3 months old , I suggest that you call the repair shop as it is under warranty
touching it yourself or having any unauthorised person fix it will void the warranty.
Apr 10, 2015 | Hoover Washing Machines
Hover OPD 714 D 7kg . What does E08 mean
http://service.hoover.co.uk/manuals/OPH714D_1.pdf
user manual
http://www.whitegoodshelp.co.uk/hoover-error-8/
here is a description of the common error your machine has
and how too solve it
hope it helps you...
Mar 04, 2015 | Washing Machines
Hi we have literally just brought a Hoover dyn 7164 d and on first check-which the manual asks us to the error code e03 appears and will not drain!!!what do we do??its full of water!how can something...
What a heap of junk of a machine. The one I own died after 13 months taking the electrics in the house out with it. A faulty heating element was the cause. They leak over their electrics with predictable results. A modified element has been fitted. Avoid this and all Hoover products like the plague.
Dec 02, 2012 | Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover WMH168D error code E08
I posted this elsewhere by mistake, I have a Hoover Optima which had an E08 fault, the forums suggested a Tachometer issue. I fixed the fault it was just the motor brushes. i made a video including testing the tacho and changing the brushes that cost me a tenner. easy fix hi I had this fault google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on you tube http://www.youtube.com/watch?v=xYn-f78GB4U if its any use.
Oct 17, 2012 | Hoover Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
ERROR E7 TOSHIBA WASHER AW8960S
check the water level switching or door sensor
Sep 09, 2009 | Washing Machines
Washing Machines Logo
478 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
