Samsung bigwash washing machine b1415j
It is a digital washer an door is locked an dont know how to open it an to get the washer working
  • smonky Apr 03, 2009
    My washing machine was making a rattling sound yesterday and today it stoped in the middle of the cycle, showing E2 on the screen, cant open the door, and its full of water. What can I do?
On the front of the machine at the bottom is a panel you can take off to clean the filter. take this off and there is a plastic cord you pull to release the door! hey presto
Posted on Nov 02, 2008
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
How to fix door on Samsung Washer model wf210anw. It makes 3 very hard clicks prior to starting.
Has the sound changed? The door lock assemble can be loud and sound like its faulty. If the washer completes cycles, then door lock is working correctly. One thing to check is the strike on the door. Look for anything that is odd or doesn't look right. A damaged strike can create extra noise. Good luck!
Jan 29, 2016 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
I have a Samsung Bigwash B1113J washing machine. The detergent tray is stuck, will not open. How do I open it?
Hi Esther, have you recently removed the drawer to clean and put it back in? Does the display show any specific error (that would be something like E+a number)?
Dec 13, 2014 | Samsung Washing Machines
I have a Samsung front loader washer that will not work on any cycle, it only makes a humming sound. The door was stuck locked shut, finally got door open after taking washer apart. I don't know what...
it might be the lock or the pump if it was still full of water
This video will show you how to open your washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2013 | Washing Machines
Cannot open Samsung bigwash door. Power trips when switched on, so cannot open electronically. Cannot find override.
I need mdl. # to search it out. In the meantime, look thru your manual if it's gone try unplugging it for a minute and letting it reboot.
Feb 16, 2013 | Washing Machines
I have a samsung big load B1415J and when the program reaches the spin cycle, it just stops completely.. any ideas what this may be?
My best guess without being there is that you have a belt that sliped or broke off. Open the washer up and look around (usually from the back of washer). The belt should be located at the bottom of the unit and should sit on a type of pully system. If you cant tell you can try to dry run it with back off and watch what happens. Hope it help Let me know what you find.
Dec 22, 2010 | Samsung Washing Machines
My samsung washing machine indicates the door is open yet its closed whats wrong
the door switch is broken or a wire has come off take the switch unit out and check its connected then check it to see that its working if you dont know how to take it to a service shop they should test it for free and tell you if it needs to be replaced then you can order one from your nearest samsung auth repairer.
hope this helps
merry christmas
please rember to rate this advice thanks
Dec 07, 2010 | Samsung WF337AA Front Load Washer
Washing Machines Logo
651 people viewed this question
Top Washing Machines Experts
