Question about KitchenAid KEYS750LQ Electric Dryer
Dryer wont start
I have a electric Kitchen Superba dryer, and when I select the time, I can hear the timer clicking, but the machine itself never starts. What should I start looking at?
  • 5,911 Answers
If the dryer does not turn on at ALL (meaning the drum does not spin and it does not heat), the main culprit is the thermal fuse (also known as a thermister on some models). The thermal fuse acts as the name implies. It is a fuse. If it blows, it must be replaced. Now...with this said, this is not the ONLY thing that can cause your symptoms. However, it is the MOST common problem and the best place to start. If the thermal fuse blew, it is generally for a reason. More commonly the problem is caused by poor dryer ventilation, or something coming in contact with the terminals (such as coins). The following link will give you some good sound advice on how to troubleshoot the most common dryer problems:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Read through the link provided and let me know if you have questions. Please post back with your COMPLETE model number (located around the door opening, or along the back of the operator console) if you require further assistance. This will give me an idea of how your dryer is constructed. I hope this helps.
Posted on Oct 23, 2008
Kitchenaid prestige dryer will not tumble
I fixed one that would not run last Halloween. A Kenmore very similar to a kitchen-aid dryer:
4 Wheel dryer DE-mystatified
Jul 08, 2012 | Dryers
Maytag Performa Electric dryer. Went to put in load and start-would not turn on. Checked breaker first. Then listed and I could hear the timer clickin on the front panel.Front door panel was full of lint....
In-laws machine did exactly the same thing. Check the thermal fuse.
Turn off the breaker.
Pop the top open with a flat screwdriver (there are two clips at the front)
There are two white wires on the right-side of the burner element, this is the thermal fuse (wires are kinda awkward to remove)
I jumpered these to wires and it started right up.
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
I have a kitchen aid electric dryer Model KEYE660WWHO, serial #1422813. My dryer won't start. The fuses have been checked and are fine. When you select the drying time, you can hear it ticking, but when...
ma be the door switch push on the door switch with a screw driver to see if it comes on if it does you have found the problem. If that does not work let me know and I will help you solve the problem.
Nov 28, 2009 | Office Equipment & Supplies
The dryer wont turn itself off
Is the timer turning?
Actually, doesn't matter, the timer is the component that turns the dryer on and off. If the dryer won't turn off via the timer then the timer is bad!
(I'm assuming, opening the door turns the dryer off.)
Replace the timer to fix.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
KitchenAid KEYS750LQ Electric Dryer Logo
303 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
