I need a manual for a GE VG4230
I have an IR-to-UHF Pro Upgrade Kit on a Dish Network System. My VCR has been used very little (is like new). I want to go through some old cassettes, but can't get it to show sign of power. I'm told by Dish tech that the connection is right and I need to go to my manual, but unfortunately it has been lost. I put a tape in but it did not go down and of course w/o power will not eject.
  • Televison & ... Master
  • 10,291 Answers
There's a fuse inside the VCR close to where the power cord enters. Check that first.
Posted on Aug 09, 2017
techman
  • 3130 Answers
SOURCE: Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
Posted on Sep 27, 2006
simplemitch
  • 752 Answers
SOURCE: VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Posted on Nov 08, 2007
SOURCE: Power shuts off
The problem is the reel sensor or associated cricuitry. I am an electronic tech and could not figure out what was wrong. I replaced sensor and sensor emitter with no change. It was not the micro. I finally gave up and told the customer I could not repair unit. No schematic or parts available from Philips/Magnavox
Posted on Jul 15, 2008
  • 3 Answers
SOURCE: VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Posted on Jan 02, 2009
SOURCE: vcr tape will not eject
If the machine is turned off and cools down, it will eject on mine.
Posted on Mar 08, 2009
I need to program a zenith tv to work with the 21.0 ir/uhf pro remote control
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
Look up codes for TV here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Feb 14, 2014 | DISH Network ES161256 21.0 IR / UHF Pro...
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
Jan 16, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
Will dish network 510 receiver work in uhf with dish 21.1 remote
No, the 510 receiver does not have a UHF input. http://manuals.solidsignal.com/DVR510.pdf You can upgrade to a 512, 612, 625, but would need your installation upgraded to be compatable (Dish Pro to Dish Pro Plus).
Sep 03, 2012 | DISH Network 322 DTV Receiver
Cannot get dish remote to work with GE 27GT271 xs stereo tv?
The remote mentioned only has about 50 codes built into it---and note: RCA and GE are the same= try all possible codes for each.
May 15, 2012 | GE 27GT271 TV
My Dish 5.3 remote no longer turns my TV on/off, nor does it control volume. All other aspects are fine.
Hi christinehacmy name is Mike Houston of DISH Network and I was reading over your post andthe remote has lost the code for your TV. There is a step called Power Scan forthe DISH Network remote, I will send a link that will help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Feb 14, 2011 | DISH Network Ir To Uhf Dish Network Remote...
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
DISH remote will not work for the first 10 minutes when the TV is turned on; so, I have to watch the channel I was watching before I turned the TV off. It seems to work fine after the initial 10 minutes.
Is the TV new? Is it a HD TV? If it is Either a 9Samsung LN(R/S)## Series , Sony Bravia/XBR# Series ,Sharp Aquos (New Models) , or Phillips ##PFL Series than the issue your haveing is what we call IR Remote Response Lost. its a light that cuts on and off that makes any IR remo not work some period of time. You have too call the TV manufactuer or use the manual for assistance. If you need details on how too fix it let me know!!!
Nov 01, 2009 | DISH Network IR Remote Control
Dish Network not working all... lights up but nothing else!
call dish network. they have all the information you could possably need.
their phone number is inside your recivers manual
Aug 19, 2009 | Universal Remote Control Dish Network...
Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Jan 25, 2009 | Durabrand HT-3915 System
Remote code for Sylvania LC420SS8
Hello frozen thank you for using FixYa.com for your answer my name is David.
Well I had to do a little bit of a search but one of these codes should help you out.
Sylvania 506, 525, 536, 566,
568, 569, 573, 600,
610, 652, 654, 656,
659, 660, 664, 665,
666, 671, 672, 674,
677, 723, 724, 729,733
I retrieved these from the following link that help you again in the future
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/IR-to-UHFProUpgradeKit132327.pdf
thank you again for choosing fixYa.com for your answers.
Nov 08, 2008 | Sylvania LC320SL8 Television
Televison & Video Logo
Top Televison & Video Experts
