GE Profile WPDH8800 washer pauses after start up.
My GE profile WPDG8800 washer pauses after startup (display reads 2 min gone by but it is actually 5 min into cycle/doesn't matter which cycle). If I dont catch it in time to un pause it shuts off and never lets me know cycle was incomplete. At first I thought it wasn't spinning properly at end of cycle (clothes were soaking wet when I went to unload, but then realized it never washed the clothes.) Help!!
4 Suggested Answers
  • 236 Answers
SOURCE: Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Posted on Feb 16, 2008
SOURCE: GE WBVH6240FWW pause/drain problem
WOW..... That was the easiest repair that I have ever had to do.... We were having the same problems with the washer pausing and have wet clothes when the washer got done. (if it would after prolonged time). The filter was gloged with all kinds of stuff.. But I only made 67 cents.... The screws are on the bottom front down at floor level... you don't even have to move the washer to clean the filter... Had it done in about 15 min. I want to thank everybody above with the info..
B.A. Murray Beaverton, OR
Posted on Nov 26, 2009
  • 1417 Answers
SOURCE: how do I pause the wash cycle so I can let clothes
hello,
what you need to do is to put OFF the power supply (electric)then put in the cloth you witch to soak .
thank you .
Posted on Jun 03, 2010
My ge profile wpdh8800 won't fill with water in any wash cycle. Have done all the troubleshooting suggestions, including cleaning lines and even turning off power to hopefully reboot electronics. Any...
You need to remove top cover to get to inlet valve (part where hoses attach). Be careful while testing parts for 120 volts. The inlet valve usually has 2 electric coils on it, some have 3 coils. While the machine is in fill cycle, check for 120 volts across each set of terminals on each coil (round plastic part with 2 terminals at each end). 1 coil is hot water--one is cold water (in some 3 coil valves 3rd coil is warm). If 120 volt is present depending on if machine is on hot or cold, the electronic boards and controls are good. Problem will be with the inlet valve itself and will need replaced. If no voltage, problem may be with control board or wiring.
Feb 21, 2015 | General Electric Profile WPDH8800JMG 4.2...
Ge profile wpdh8800
too much to check. buttons, wiring, open circuits, fuses. what was it doing when it went off? that may give you a pointer as to where to start looking.
Nov 09, 2013 | Washing Machines
Ge profile wpdh8800
the spin cycle is run by a belt-I'd say something is stuck like the drum or you just have a bad belt or probably both. you'll have to do a tear down to see for sure-to check bearing in tube try to turn by hand to see if its tightCheers-Denny
Oct 11, 2013 | Washing Machines
Faulty stop pause button on ge profile wpre8150
This is caused by a faulty control board. The button you referred to is part of the board and the control board manages all aspects of the wash cycle. You will need to replace the control board. Here is a link to the part you need.
Oct 13, 2012 | GE Profile WPRE8150K Top Load Washer
F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
Close the washer and press the START/PAUSE/Cancelbutton to remove error displayed and restart the cycle. If it doesn't work, it means thatthe valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens Washing Machines
Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle. If it doesn't work, it means that the valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens WFXD8400UC Front Load Washer
Have a GE Profile bottom-freezer refrigerator, model #PDS22MBSBWW, serial #RL053351, approximately 5 yrs old. It has recently started making a "clicking" sound which goes on for anywhere from 1...
For the clicking if the fridge has been off for at least 5 min. and clicks when it tries to start then it may be the start relay on the compressor . If it does not stay off for at least 5 min then it may be the control which may also be why your display is not working.
Nov 30, 2010 | GE Profile PDS22MBS Bottom Freezer...
I have a GE Refrigerator model PD520SFSBRSS that
Strange sounds can be deceiving as to their actual location. Your problem could be one of several:
* icemaker
* freezer fan motor
* compressor
* condenser fan motor
Contact an appliance service company.
Feb 15, 2010 | GE Profile PDS20SFS Bottom Freezer...
Will not power on
I THINK YOUR TIMER MIGHT BE GONE ON YOUR WASHER. CALL A REPAIRMAN AND EXPLAIN YOUR PROBLEM. HOW OLD IS YOUR WASHER?
May 15, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
