Question about Universal Remote Control MRF-260 Barrier-Free Addressable RF Base Station Remote Control
How do you turn on the mrf-260? my connect button is staying red.
While watching TV last night, the screen changed to cable, analog - we have directTV satellite. It appeared the remote was working but not connecting with anything on the screen. Upon checking the apparatus downstairs, I noted the red light of the connector stayed on so it seems it is off therefore not connecting. How do I get it back on? All plugs are secure.
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
I have a direct tv remote how do i program it to the MRF-260
I believe DirectTV has excellent customer service reps that would be delighted to help you!
Jul 24, 2011 | Universal Remote Control MRF-260...
I connected my GE TV model 13GP301 to a Magnavox DTV Digital to Analog Converter using RF cable. I mistakenly changed the setting on the TV to the video cable connection (red, white, yellow). Now no...
if this shows "vid" on screen turn it back to tuner input with input button on original remote.... could be marked who/input on some....go to mrremote.com if you haven't got it..............good success, meder's tv service
Aug 11, 2010 | GE Televison & Video
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Cannot program Emerson Jumbo Univ remote to DirectTV
Try this: Press and hold the TV Power button and the Dirctv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 27, 2008 | Tivo DirectTV Remote Remote Control
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
TV
If you are using cable and the signal is connected to the TV through the regular cable wire, then the TV must be in TV mode to work properly. If you are using a cable box with that TV then the TV must be on channel 3. If the screen shows AV 1, then the TV is in the AV mode (red, white and yellow RCA jacks), and you most likely accidently hit the INPUT button on the remote. Pressing 0 3 or INPUT a couple of times on the remote should bring your picture back.
Aug 09, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Universal Remote Control MRF-260 Barrier-Free Addressable RF Base Station Remote Control Logo
46 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
