Question about Toshiba E-Studio 3511 Color Copier
Trouble networking copier to computer
I want to be able to use this copier as a networked printer for two computors. I used my time warner connection to rout both computors thru, and a cable from that hub directly into the copier but am still unable to get a connection. i had downloaded the drivers but it still seems that my computors can't read it. wats up wit that
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
You might have to set up the nic card in the machine. set it to a static IP address (not DHCP), then ping it from a PC..
If you can ping it, then instalation should find it!
I dont understand " time warner connection to rout both computors thru " ?
you should have.
One broadband Modem...
One Router which all pcs and machine's are connected to...
do ipconfig/all to figure out the pcs IP address, arp -a shows the arp table. determine what IP address to give the machine.
the machine should have a nic card with a light on it, if that light is green when you connect the cable, then the nic card is working.
then proceed to install the drivers to the PCs.
Posted on Oct 23, 2008
Networking with hp 2355
This model printer has only an USB connection and needs to be connected to a computer.
To use this printer on your network, the printer needs to be connected to your computer and must be configured as a shared printer.
Your computer and printer must be switched on at all times for the other computers to print on this printer.
Nov 09, 2012 | HP Office Equipment & Supplies
Tip
Network Troubleshooting in windows
<p>Some Time Network trouble shooter faced some problem in but they can't solve out where is the exact problem. Yes it create critical situation some time to find out where the problem is. In windows based OS have a feature to take out problem. Network trouble shooter is the feature where we can recognise the trouble of hardware, software or network. Here I will describe about <span>how to troubleshoot a Windows XP-based home network. Usually it will describe also about a network structure, how to use the Home and Small Office Networking Troubleshooter, and how to troubleshoot basic connectivity, and how to resolve file and printer sharing issues. If you have problems with your home network, follow the steps in this article to help isolate and troubleshoot the configuration of your home network's basic connectivity, and file and printer sharing. First, try to identify and resolve the issue by using the following steps. </SPAN><br> <p><span><span> </SPAN></SPAN>At <span>first you have to know the kind of network structure that using there. If you are not sure, go to the "Home-network structures and their configurations" section. To identify the problem first </SPAN><span>Click starts and then click </SPAN>Help and Support<span>. </SPAN><span><span> </SPAN>After that </SPAN><span>Pick a Help Topic, click Networking and the Web. </SPAN><span><span> </SPAN></SPAN><span>Under Networking and the Web, click Fixing networking or Web problems, and then click Home and Small Office Networking Troubleshooter. </SPAN><span>Answer the questions in the troubleshooter to try to find a solution. </SPAN><span>Before you troubleshoot home networking issues, first determine the network structure you are using. The network structure is the arrangement or mapping of network elements such as links and nodes, and the physical connections between them. There are several common home-network structures.</SPAN><br> <p>If in that Lab the computers are connected to a hub, where only one computer has Internet connection shared by using Internet Connection Sharing<b><span>.</SPAN></B><span> </SPAN><span>In this configuration, the computer that shares the connection generally assigns IP addresses to other computers on the home network. The computer that is sharing the connection will have IP address 192.168.0.1 configured for the adapter that is connected to the home network. Other computers on the network will have addresses in the range 192.168.0.<span>x</SPAN>, where <span>x</SPAN> is a number between 2 and 254.</SPAN><br> <p><span> </SPAN>If t<span>he computers are connected to the Internet</SPAN> through a broadband connection, then<b><span> </SPAN></B><span>this configuration is also known as an edgeless network. In this configuration, the computers on the home network each have an IP address that is provided by the Internet service provider (ISP). The addresses that are used vary, depending on the ISP. </SPAN><span></SPAN><br> <p><span>So Network trouble shooter is very useful and easiest process to identify or troubleshooting a network problem.</SPAN>
on Mar 24, 2011 | Microsoft Windows XP Professional With...
Printer does not work with Time Warner wireless router?
It works with any router. Just install the software and follow the prompts - it will guide you through the process of connecting your printer to your network.
Aug 28, 2012 | Lexmark Prospect Pro205 Wireless...
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
How to get into network settings
look my friend to get out from this troubles of network if yo want to connect with one computer use lpt cable is fast and easy
Feb 02, 2011 | Ricoh Aficio 450 Copier
2170W wireless connection to mac computers
My suggestion would be to connect an ethernet cable from the printer to the router. This is a more stable connection for the printer on the network.
All of your wireless computers will be able to connect to it and print to it as long as they are connected to the network.
To get the printer back in wired mode, you will need to reset the printer and network card of the printer.
1. Turn off power
2. Hold down go Button while switching back on
3. Wait 2 secondes before letting go and press the go button 8 times quickly
4. Wait for the unit to finish warming up
5. Repeat steps 1 and 2
6. Wait 2 secondes before letting go and press the go button 7 times quickly this time
7. Wait for the unit to finish warming up then plug in the ethernet cable.
Mar 28, 2010 | Brother HL-2170W Laser Printer
C 6280 Photosmart All in One would like to hook to our computor have the code to do so but not sure where to use same
Are you connecting the print using usb cable or in network. While connecting usb cable it will not ask ant code. I think you are connecting the printer in network.????
Mar 13, 2010 | HP C6280 All-in-One Printer
Trying to use the bizhub 200 as a network printer.
First thing your going to have to do is go into the administrator setup of the copier by pressing the utility counter button. The password is 12345678 by default. Select network settings and enter an available ip address for your copier along with the subnet mask and gateway settings.
These settings work for a 300. I don't know if any of these changed for a 200 series. Let me know if they do.
Dec 01, 2008 | Office Equipment & Supplies
Network printing problem
A couple of possibilities you can try:
1. Use the installer CD on the other 2 PCs as well. When prompted, instruct installer that the printer is on a network; and/or
2. Use the parallel connection instead of the USB (or the other way around); and/or
3. Un-check the auto turn-off of USB devices in the Power Management tab of the USB Root Hub Properties.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 18, 2008 | Kyocera Mita FS 1010 Laser Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
Toshiba E-Studio 3511 Color Copier Logo
232 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
