Question about Pontus PNAV-3550 GPS Receiver
PNAV-3500 error message regarding memory
Help! Our PNAV-3500 keeps displaying an error message that says "PMN out of memory 16". What does this mean, can i fix it myself? We are leaving for Florida soon and need our navigation system!!! Thanks!
  • 2 more comments
  • rachroy Oct 23, 2008
    How do I dump my memory?
    I have done that, in fact that is when the error message began appearing, after i pressed the reset button. I had pressed the reset button because it was displaying an error message that was written in Chinese. This was occurring while trying to enter an address. This is really a mess.
    OK I've tried this several times. I'm not getting a screen with a black dot, just the usual intro screen and then the error message. Will throwing it out the window help?
    yes, thank you very much.
    Brigadier General:
  • 6,966 Answers
I suspect firmware issues and/or condensation/water damage. Considering the time element and the importance of the GPS in your forthcoming travel and if after everything else and the unit would not function, then I believe there would only be two (2) options:
  • seek the services of a reputable service shop who can repair it on time and guarantee it; or
  • acquire a replacement.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 23, 2008
  • 728 Answers
If none of those solutions work, you might need to get an update or reinstall the software from the cd that came with it. This will be best because the memory will be cleared from the memory stick so you can have a fresh start and no more of the memory problem.
  • Jazz Boyce
    Jazz Boyce Oct 23, 2008
    Try this one. It should work. It is the best option.
    Scholar:
  • 136 Answers
Pressing the reset button on the lower left side ur device will reset ur unit.try and get back if u need any more help
    Master:
  • 538 Answers
Seems that perhaps your settings and information has hit the max on that device. maybe it is time to dump the memory and only keep what is needed..
  • 1 more comment
  • A Womans Computer Man
    A Womans Computer Man Oct 23, 2008
    a question for zou..did you repost this question or did that rating for Thanks for Trying come from your end?
    try this(from another posting for tips and tricks under this model number)
    1- Turn off unit. 2- press and hold the bottom right corner of the
    screen. 3-While still pressing and holding bottom right corner, press
    and hold power button and continue holding both until a white screen
    appears with a black dot. 4- follow the on screen directions and your
    unit will be back to the day you first got it.
  • 13,433 Answers
Have you tried to reset the gps? I will look into this and post more to you in a minute.
  • Ekse Oct 23, 2008
    Try to reset the device, there should be a reset button or a hole that needs to be pressed to reset the device, the device is most likely out of memory, try to clear up some space into the device or the memory card. Hard to find details on your product, I will keep looking.
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
Pro-Plus error Panel 03
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
Remember PCA, mean Printed circuit assembly with the componentsattached.
God bless you
Jan 14, 2013 | Exercise & Fitness
My PIU Cube 16 Olimpia Splendid portable air conditioner is displaying an error message f1, can anyone solve what this means? Thanks
It means 'Dirty Filter' once cleaned you must press and hold down the 'On' button for 5 seconds and the message will remove.
Feb 24, 2011 | Heating & Cooling
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Memory card error
If you get a message on your camera such as "Memory Card Error" AND there are no photos that you want still on the card, the first step is to format the card through the camera menu (Note: if you have an xD card, once you re-format your card any photos cannot be recovered.). Read your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
If you do have valuable photos on the card, then DO NOTHING (do NOT format the card, do NOT take any more photos). You need to undertake a photo recovery. For options on Photo Recovery, click here. Once you have recovered your photos and archived them, then reformat the memory card through the camera as outlined above.
Keep us updated (remember to rate this answer).
Dec 22, 2010 | Canon Cameras
SR-16 gives message "ERROR: 01" when powering up
You likely have lost the internal memory data. This can be due to a power surge or that the internal battery has been depleted. The battery may need to be replaced.
You should reset the unit and reload the data, The manual is available online. Search Google for it.
The manual STRESSES the importance of backing up the data.
If you don'thave the backup, you MAY need to find another SR-16 owner to clone the data from.
Jul 01, 2009 | Alesis Sr 16 Stereo Drum Machine
Missing audio in video recording
my sahara notbook display & audio driver is missing
Feb 22, 2009 | 3dfx Voodoo3 3500 TV (16 MB) Graphic Card
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Pontus PNAV-3550 GPS Receiver Logo
137 people viewed this question
Top Pontus GPS Experts
Will Halftowaite
Are you a Pontus GPS Expert? Answer questions, earn points and help others
