Question about Optoma RD50 50" Rear Projection HDTV-Ready Television
SHADOWING ON THE LEFT HAND SIDE OF THE SCREEN THERE IS ABOUT A 12 INCH SHADOW. YOU CAN STILL SEE THE PICTURE BEHIND IT, IT'S LIKE THE LIGHT IS'NT ON THE FULL SCREEN...THEN ON THE RIGHT HAND SIDE THERE IS A 2 INCH GAP ON THE BOTTOM AND GOES UP TO ABOUT 4 INCH GAP AT THE TOP..
    President:
  • 3,130 Answers
LOL Thanks Take.. Yea this set is a DLP set and uses a bulb that gets weak or my move and get dislodged .. Its not a repair even for the consumer or you can mess up the DLP display .. Let a pro realighn or replace the bulb assy Good Luck PS its not as simple as replacing the builb
Posted on Aug 08, 2006
    New Friend:
  • 163 Answers
Jesus have you move that tv thats new to me but surely techman know about.....good luck
SOURCE:
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
3 problems 1. TV shuts off and on automatically. 2. 2 inch band on left side of screen 3. No picture at all
The band or shadow on the left side of the screen definitely sounds like a defective light tunnel.As for the intermittent pix and shut down this could be the lamp if you have not already changed it.
Oct 15, 2009 | Samsung DLP HL-P5663W 56" TV
Shadows on lcd
Why does my lcd proton Television have a long black streak on the right side of the screen?
Sep 25, 2009 | Televison & Video
Where is the signal light flasher located on a 1985 honda shadow vt500c?
Hello jd...the flasher will be on the left hand side of the bike behind the side cover.... part # 38301-mf5-771. It should be mounted inside a rubber boot. Shop around, most Honda dealers will sell this for about 65 buxs...but you can find it cheaper.
Hope this will fixya up.
May 19, 2009 | 1985 Honda VT 500 C Shadow
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Shadow down left hand side of screen
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Jul 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Screen Problem Television Set
Need some more details the problem you describe could be anything from a simple convergance problem or the light tube going bad in a light engine, one problem about $80.00 to fix the other, slightly over a $1000.00
Mar 19, 2008 | Televison & Video
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Optoma RD50 50" Rear Projection HDTV-Ready Television Logo
194 people viewed this question
Top Optoma Televison & Video Experts
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
