Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Do i need converter box with Toshiba tv 46H83
SOURCE: toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Posted on Jul 30, 2007
  • 10 Answers
SOURCE: Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Posted on Apr 19, 2009
  • 150 Answers
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
Posted on May 13, 2009
  • 1779 Answers
SOURCE: turned on tv have sound but no picture. toshiba
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Posted on Oct 03, 2009
tlm931
  • 273 Answers
SOURCE: the toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Posted on Nov 02, 2009
Apple tv has no sound on my toshiba 46h83 tv
How are you connected and in what way? You should be able to rule the set in or out:
First: does the set have sound with only a DVD player connected to a rear input?
Second: are the speakers turned to OFF in the main menu?
give as much information as you can so I may be able to help.
Dec 10, 2012 | Toshiba 46H83 46" Rear Projection...
Have vertical lines across the tv. Started as something that happened right when I turned the tv on (for 5 mins or so). Now it's all the time. Toshiba 46H83
you more than likely have a bad panel inside of your tv. you can have someone repair it but it's not recommended as it's pretty expensive. You should just invest in a new tv.
Jul 23, 2010 | Toshiba 46H83 46" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Turned on tv have sound but no picture. toshiba 46h83
Oct 03, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83
May 13, 2009 | Toshiba 46H83 46" Rear Projection...
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Nov 14, 2008 | Toshiba 46H83 46" Rear Projection...
Toshiba 46h83 tv projection not full orizontal pic
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Horizonatal lines on Toshiba 46H83
If the repairman you had look at the set is used to working on projection sets, have him come back and Re-Solder Connector Px801 (Edge Connector) On The G-Hyper Module. (Pins 1 And 2 Of Px801 probably needs to be Re-Soldered) Otherwise, find a different repair person.
Dec 19, 2006 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
