I have a skid steer with an aftermarket auxiliary heater. The motor was seized, so I pulled it out to replace it. I cannot find a replacement, so pulled the motor apart and polished the shaft. After lubing the bushings and putting it back together it spins nice on all three speeds. The only issue is that it spins backwards! There is a direction arrow on the housing, and it spins the opposite direction. Even the fan is pitched for the indicated direction. Motor is 12v D.C. What have I done wrong? Thanks. Clint.
    Problem Solver:
  • 7 Answers
Wired up wrong
Posted on Feb 11, 2012
  • themoparguy Feb 11, 2012
    Nope, tried that. Even on the bench it turns backwards. Even tried using the body of the motor as the ground, and every wire as the ground. No luck.
Is it a big job to replace the brakes on a john Deere 250 skid steer
check with the service dealer
most skid steer loaders do not have brakes in the normal sense but have valves that lock the hydraulic fluid in the drive motors and so prevent them from turning making them brakes
Aug 09, 2016 | John Deere Garden
2008 dts caddy blower motor resister location
Your not going to like to hear this , but you'll need to take the dash apart !
Blower Motor Resistor Replacement
Preliminary Procedure
  1. Remove the HVAC module. Refer to HVAC Module Assembly Replacement .
  1. Drain the cooling system. Refer to Cooling System Draining and Filling .
  2. Recover the refrigerant. Refer to Refrigerant Recovery and Recharging .
  3. Remove the evaporator tube from the thermal expansion valve. Refer to Air Conditioning Evaporator Hose Assembly Replacement .
  4. Remove the heater hoses from the heater core. Refer to Heater Hoses Replacement .
  5. Remove the brake pedal bracket assembly. Refer to Brake Pedal Assembly Replacement .
  6. Pull back and reposition the carpet.
  7. Remove the lower instrument panel (I/P) support brace. Refer to Instrument Panel Center Support Bracket Replacement .
  8. Reposition the auxiliary air distribution duct. Refer to Auxiliary Air Distributor Duct Replacement .
  9. Remove the instrument panel carrier. Refer to Instrument Panel Carrier Replacement .
  10. Disconnect the HVAC module assembly electrical connectors.
HVAC Module Assembly Nut (Qty: 5)
Tip
Tighten the nuts in sequence.
Tighten
9 N?·m (80 lb in)
HVAC Assembly Module
Disconnect the blower motor resistor electrical connector.
Jul 28, 2016 | 2008 Cadillac Dts
Anyone have auxiliary hydraulics layout particularly where/how its plumbed into control valve
PDF]2013 Skid Steer Loader Parts - Tractorpartsasap.net - All ...
www.tractorpartsasap.net/.../2013_Skid-Steer-Loader_Parts-Catalog.pdf
Auxiliary Heaters . ... Hydraulic Lift Cylinder . .... Service Manual - Tells you how to take the skid steer apart, how to fix it, and how to put it back together ... in the serious repairs or restoration, you need the shop service manual; It can give you many ...Bobcat. 520, 530, 533. 122571. $48.00. Bobcat. 500, 600, 610. 122521.Missing: layout ‎plumbed ‎into
[PDF]PARTS REFERENCE GUIDE - Service Motor Company
servicemotor.com/catalogs/PM-8490.pdf
HITCH PARTS. 125. HYDRAULIC PARTS ... Find the same heavy-duty quality builtinto Case IH batteries for your truck ... lawn and garden tractor, Case IH has the ... Whether it's off-road, lawn and garden, automotive, or marine application, look ...... 12 Gauge. Aux. Lead, 3/8" Eye with B- Splice 12". ZQC708101. 4 Gauge.Missing: layout ‎plumbed ‎1977 ‎clark ‎520
Massey Ferguson Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages9/
What hydraulic fluid is needed for a Massey Ferguson 390 · MF135 Selling ...... Hydraulics quit working after installing Aux Hydraulic control valve. MF 135 lift
Case Farm Tractor Parts and Manuals - Yesterday's Tractors
Dec 12, 2015 | Garden
Remove power steering pump on a 2007 chevy avalanche
Power Steering Pump Replacement « on: 05/04/07 06:28 PM » I recently had to replace the power steering pump in my 1500 Z71 Av and tried following the manual. My mistake. If anyone has to do this replacement, this is a much easier way:
1. Disconnect the battery
2. Take the upper fan shroud off.
3. Take the skid plate and whatever that plastic thing in front of the skid plate is off
4. Disconnect your power steering lines and the wire from the back of the power steering pump
5. Take the alternator out (2 bolts, one nut, one wire connector)
6. Take the nut off that attaches the right angle bracket from the power steering pump to the engine
7. Take the bracket for the power steering pump and the alternator off the front of the engine.
8. Then you can get to the power steering pump with no trouble at all. Goes back in pretty easy too.
Happy motoring. Hopefully no one else breaks the power steering pump shaft in half, but I'm sure someone will.
Sep 18, 2015 | Chevrolet 2007 Chevrolet Avalanche 1500...
07 chevy hhr we replace the power steering motor but the steering still hard we change the fuse on the side panel but not sure wat fuse needs to be change under the hood
You may have a damaged steering column or simply the auxiliary belt for the power steering pump has snapped. worth a check.
Dec 23, 2013 | Cars & Trucks
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Motor has seised up on our Reddy heater 55 how do we fix it?
Question- are you sure the motor has seized? If the rotor shatters it can bind the motor.
If the motor has seized it must be replaced, It is not serviceable.
Nov 24, 2010 | Reddy Heater-30-55,000 BTU Variable
Heater blower motor replacement -1997 Dodge Grand Caravan
Remove the cover plate on the passenger side of the heater box, 3-4 screws.
Unplug the motor assembly, remove 3-4 more screws that hold the motor in place and pull it down from its position. Get an aftermarket motor and installed it in the original housing with the original squirrel cage.
Installation is the reverse of removal.
Nov 23, 2009 | 1997 Dodge Grand Caravan
1999 JAGUAR XJ8 L HAS NO HEAT
There is an electric auxiliary water pump for the heater near the bulkhead. This is likely to be seized and may require replacement, quite a common fault!
Jan 28, 2009 | 1998 Jaguar XJ8L
2004 Ford Expedition rear floor cool/heat
Item Part Number Description 1 — Air inlet door 2 — Temperature blend door 3 — Headliner airflow 4 — Auxiliary mode door 5 — Floor airflow 6 18476 Heater core 7 19860 Evaporator core 8 19805 Blower motor
The auxiliary A/C and heating system has the following features:
  • The auxiliary A/C and heating system is functional whenever the instrument panel mounted A/C control is in any position except OFF.
  • The auxiliary blower motor recirculates the air inside the vehicle. Outside air is not available to the auxiliary system.
  • Air is cooled and dehumidified by the auxiliary A/C evaporator core only if the instrument panel mounted A/C control is adjusted to a position that requires A/C compressor operation.
  • The temperature blend door and the auxiliary mode door are controlled by electric actuator motors.
  • Movement of the auxiliary temperature control between COOL and WARM causes a corresponding movement of the temperature blend door to mix air flowing through and around the auxiliary heater core.
  • Movement of the auxiliary mode control between PANEL and FLOOR causes a corresponding movement of the auxiliary mode door to direct air flow between the panel (headliner) registers and the floor duct.
I would say the auxiliary mode door (#4) electric motor is not wokring.
Auxiliary Blend Door Actuator —Air Distribution Removal and Installation
  1. Remove the RH quarter trim panel cup holder and access panel.
  1. Remove the screws.
  1. Disconnect the blend door actuator electrical connector.
  1. To install, reverse the removal procedure.
Jan 14, 2009 | 2004 Ford Expedition
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
