Question about Executone (2512511) Corded Phone
How do I change the main incoming greeting on Executone Phone system
3 Suggested Answers
SOURCE: EXECUTONE MODEL 64 Phone
quick way is to delete them both and re-record
Posted on Aug 09, 2007
SOURCE: Executone 64 System: Only certain extensions ring
http://www.executonesystems.com/documents/IDS_UserGuide.doc
Try going to this user guide and see if this helps.
Posted on Jan 26, 2009
How can I change the system main greeting on an Executone Model 64?
from any phone dial 436 and then press #, then enter managers mailbox usually 5000 and the password, by default it is 5000.
then 3, 8 and 1# for CCR 1,(or 2# for CCr2 and so on) and follow the prompts
if you need additional help, call me. 2033955027. Joe
Sep 05, 2014 | Executone 64 Corded Phone
How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
May 14, 2010 | Executone 64 Corded Phone
Need to change the main greeting in the company voice mail
The voice mail comes from an external box to the TD phone system cabinet. If it's Panasonic branded, it could be any one of several models designed to work on the TD product. The white boxes are TVS models in the U.S. (50,80,90,100,125,225 etc) the blue/black boxes are the newer TVA models (50,200). Each VM has the abillity for at least 100 "custom" greetings and, in some cases 32 company greetings. We use specific custom menus in the TVS product, but not in the TVA product because a TVA is set up visually.
Both models record and change greetings from mailbox 998, the message manager's mailbox. Once you get there, you choose option 5 then some other number like 4 for custom greetings and change the greeting (1-100) by following the prompts. Which one and how you get there is a lot easier if you have a manual.
So, since it's beyond the scope of a free forum, and you didn't post which VM you have, either consult your installer, manual, or comment back with your VM model number and I can give you a link to a manual.
If you absolutely want to do this yourself, you will need a computer with a serial port and a terminal program to access the TVS systems, or a USB port and maintenance software for a TVA.
Carl
Oct 29, 2009 | Panasonic KX T7436 Corded Phone KX-T7436
I have a vodavi phone system and am trying to turn off the incoming call ringer, how do i turn it off and on at wil. Thank You
Break into admin section of voicemail, go to system greetings, select greeting you wish to change. Need more info, email. If this is helpful, please post as such
Mar 04, 2009 | Vodavi Infinite DVX Plus IN-1414 Corded...
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
Need to change greeting
main system greetings can be changed via the administrator mailbox, dial your voicemail huntgroup number, on answer press the * key and supply the admin mailbox number which is usually 999 or 9999 the default pincode is 8642 then follow the voice prompts to change the system greeting.
Jan 30, 2009 | Mitel 5220 IP Phone
Program error
what system is this?
does the Program error apear when you press a button?
if it does, then the keys need to be reprogrammed.
let me know and I will help you with the rest.
Jul 20, 2008 | Executone IDS 82200 Corded Phone
Aug 08, 2007 | Executone 64 Corded Phone
Executone (2512511) Corded Phone Logo
18 people viewed this question
Top Executone Lands Phones Experts
magna buff
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
