Replacement band for Fossil CH-2464
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
SOURCE: How to remove links from Fossil metal band?
I did not know this was this easy, all this time with this problem. I like the internet.
Thanks!
SOURCE: purchased fossil ladies watch am4183
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
SOURCE: Watch Too Small
Extra links for your Fossil watch can be ordered by calling Metro Service Center at (800) 842-8621.
For all watches we offer up to two additional links. There is a $4 shipping & handling charge for all link orders. If more than two links are needed, you will be charged $3 for each additional link requested.
Please note that each additional link adds approximately inch to the watchband. Link quantities are limited and are not guaranteed to be in stock.
