Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Agitator will not work
I have a kitchen aid washer and wanted to know if the instructions for replacing the agitator dogs worked on kitchen aid also.
the problem is that the top part of the agitator will not work, but the washer still spins out and does every thing else.
thank you for your time
    President:
  • KitchenAid Master
  • 2,651 Answers
Kitchen aid is hte same as the whirlpool so if you have directions for that one it will work on your current one,, part number 80040
Posted on Nov 06, 2008
My kitchenaid washer is not agitating normally, barely agitates and I'm looking for a manual for my model KAWE900TAL0, is there one available?
Hello.
Repair manuals are indeed available but are $15-20 and take a average of 2 weeks to arrive.However bing very experienced in all brand of the Whirlpool washer which makes the Kitchen Aid brand,i believe 1of 2 things will cause that.
Firstly if it agitates on the lower portion and its just the upper barrel of the agitator that isn't working plus it also spins the water out normally and the clothes dont come out dripping wet,its going to be the parts in the upper agitator called the dogs because they appear to look like dog paws,are wore out and not catching. I have included 2 youtube videos showing step by step how to replace the dogs and the part ill talk about in a minute. The dogs could be replaced seperatly or the kit as shown in the video,ill give you part numbers at the end of the email.
The other thing it could be espically if it doesnt agitate at all AND also doesnt spin well leaving the clothes dripping wet when removing them to the dryer.will be a broken motor coupler and i have included a video for replacing that as well
The part that it turns out to be could be purchased at your appliance parts store or on there at REPAIRCLINIC.COM or elsewhere on line at;
searspartsdirect.com
appliancepartspros
apwagner.com
midwestapplianceparts.com
http://www.youtube.com/user/RepairClinic?v=0GQh8JLqVv8&feature=pyv&ad=5457341621&kw=agitator dog replacement video
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler motor coupler video
PART NUMBERS
dogs alone 80040
complete dog kit 285811
motor coupler 285753A
Good luck,i hope i have been able to help you fix your washer,
Gene
Aug 13, 2011 | KitchenAid Washing Machines
The top part of the aggatator does not turn
Washer has trouble agitating... Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid.
Replace the dogs its a easy fix for you
Dec 28, 2009 | Whirlpool Washing Machines
The bottom part of the agitator will turn, but not the top part
The agitator has two parts. One is the bottom agitator and then you have the top agitator that moves the clothes around. If the top part of the agitator is not moving. You probably need to replace the dog ears. Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid. -- click on this link directly to get the detailed instruction for replacing dog ear
http://www.american-appliance.com/catalog/newsdesk_info.php?newsdesk_id=136
to remove the whole agitator check out the instructions as follows:
(1) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1, picture2.
(2) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator. also you can get the exact required parts from www.repairclinic.com
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 25, 2009 | Kenmore Washing Machines
Agitator not working
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Kenmore agitator clutch dog replacemant?
The followng link explans how to replace the agitator dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Read through the instructions and let me know if you have any questions. I hope you find this information helpful.
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Directios for changing agitator dogs
take the cam out take the yellow bushing off, put new dogs in, put yellow bushing back on, put agitator back into washer, put cam back in with dogs inside it, facing down, put bolt back in and cap. new dogs usuaully come with instructions.
Feb 10, 2009 | Whirlpool Washing Machines
WHIRLPOOL MODEL LXR9445JQ0 WASHER. UPPER AGITATOR NOT WORKING VERY WELL, EXCEPT ON SMALL LOADS. LOWER AGITATOR WORKING ALL THE TIME. UPPER AGITATOR CAM BAD? HOW HARD TO REPLACE?
You need to replace the agitator dogs. Yes...there is such a thing. These are four small plastic pieces under the agitator cap that grip the upper agitator, preventing it from back spinning under a load. Searspartdirect.com has an excellent illustration of how your agitator is assembled. Just type in your model number and look under the "Agitator, Basket and Tub" heading. The dogs are listed as item 10 (part #80040). For a bit more you can order the entire upper cam replacment kit (which includes the dogs) as item 9 (285811). For instructions on how to replace, just follow this link:
This is an expensive and very simple repair. If you require addtional assistance, let me know. I hope this helps you.
Aug 27, 2008 | Whirlpool Washing Machines
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
180 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
