Question about Konica Minolta Di1610 Copier
Error code f-51-6 - Konica Minolta Di1610 Copier
  • waverider784 Oct 23, 2008
    error f-51-6 konica 7022 copier
  • 145 Answers
This is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Posted on Oct 25, 2008
This 51-6 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Posted on May 21, 2009
What is error code 51?
search for it on Google make model and error code 51
Jul 28, 2015 | Washing Machines
Error code 51 Denon Professional DN-981F Minidisc player
It is not always the machine. Sometimes it is a bad disc ... or a batch of them if they are from Memorex.
Do the MDs play on other machines?
Nov 05, 2014 | Denon Audio Players & Recorders
I can't open my tv script ? Error code 51 showed up? How do I open it
you read your tv catalogue ,you find there opening portion briefly.
Mar 26, 2013 | Computers & Internet
E03-51 error on dp 6030
Hello Sir; the error code you indicated is corona wire problem, check the charge & discharge unit the corona wire is broken or not, replace it if it does.
Oct 06, 2012 | Office Equipment & Supplies
Panasonic pro II commercial microwave, error code F 51
Short in side Magnetro HV circuit, can cause blown fuse or c.breaker, you must test the magnetron, God bless you
Jul 13, 2012 | Microwave Ovens
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
Aug 29, 2011 | Maytag Washing Machines
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Unable to print 51, Brother MFC-845CW
Error code #51 - encoder strip may be stained with ink, purge cam shaft broken.
Note: error codes for inkjet printers are different than lasers.
Aug 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Konica Minolta Di1610 Copier Logo
1,821 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
