Question about Audio Technica Audio-Technica ATM31A Professional Microphone
Audio technica ATM31 mic manual
Where does the battery go? I need to replace it but cant figure it out!
thanks
    Sergeant:
  • 243 Answers
Try twisting off the diode capsule :)
Posted on Oct 25, 2008
About an inch from the top of the handle part of the mic there is a red ring (that has Audio-technica info).  Twist apart just below the red ring.  Do not use the windscreen for leverage while you are trying to unscrew the two sections. as it can break loose. A pair of pliers works great. (If you are afraid of scratching the mic then put a piece of fabric between the pliers and the mic).
Posted on Feb 16, 2009
My mic wireless mic sounds like it has a ground loop hum when it is in standy mode and when it is all the way on. I've switched cables and batteries what could be causing this hum?
You could try another power adapter on the receiver, maybe this one blew the filter capacitor. I doubt your problem being the mic, rather check the receiver. Luck !
Nov 10, 2014 | Audio Technica Audio-Technica ATW-T202...
How to dissasemble Audio Technica earworn mic connector? Need to repair Audio Technica earworn mic with damaged cable.
You probably can't disassemble the factory connector. What you CAN do is find a replacement connector (internet) that's designed for retrofit to your cable and install it on the good section of the cable.
Feb 19, 2018 | Audio Players & Recorders
How do I connect my audio-technica lapel mic to a device with an amplifier
I imagine their website may address that for your unnamed specific model ('lapel' isn't specific); and/or the manual that came with the amp. Most mics need preamps.
http://www.audio-technica.com/cms/site/1635df9c8c5039f1/index.html
Jun 23, 2011 | Audio Players & Recorders
I have several microphones, one's Audio Technica ATM61HE hypercardioid mic, and it has (low) volume issues. i brought it to audiophile before, they don't have the spare part on hand though, and the part's...
You might consider sending it in to Audio technica for repair. They're really customer oriented and alot of times they'll repair and or replace for just cost of shipping. Try contacting them directly.
Apr 30, 2011 | Audio Technica Audio-Technica ATM61HES...
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
How tointerface an audio technica mb 4k to computer
As long as the microphone is getting power (via a seperate phantom power unit, or using batteries, the MB 4k can use AA) you should be able to plug into a computer with no trouble, as long as a couple other things are set. You'll need two things in addition to your mic and battery.
1) You need an adapter to go from XLR to 1/8". Go to www.sweetwater.com and search for "XLR to 1/8". They are around $10.
2) Your computer must have a "mic" level input. It is probably a red connector. If your computer only has a "line" level input (probably blue), then you will have to use the mixer, or some in between unit to up the output of the mic to line level.
Not sure why your mr8 is outputting so low. Make sure you have phantom power turned on.
Best of luck!
Jun 19, 2009 | Audio Technica Audio-Technica MB 4k/c...
HELP
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Jul 29, 2008 | Audio Technica ATW-T52 Professional...
Want work
You need to fine tune (to connect wirelessly) ur wireless mic to your wireless receiver unit. Put a fresh battery to ur Mic then power-up ur receiver unit, find the right channel for both unit.
Aug 05, 2007 | Audio Technica Audio-Technica DR2600...
Audio Technica Audio-Technica ATM31A Professional Microphone Logo
1,078 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
