Question about Bosch 15.0 Amp Brute Breaker Hammer With Service Minder Shock Mounted Handl
Bosch Brute Breaker
I own a Bosch Brute hammer that runs good, just will not hammer with any force. Can you let me know what I need to do to fix the problem. I have torn the unit apart, and looked at the cylinder/driver assembly. Everything looks correct, but it still does not work. Can you let me know what I need to look for? Let me know. Thanks,
Frank Morton
frank@kortebros.com
    Novelist:
  • 99 Answers
What age is the machine? If it is fairly new it might just need to be run a while for the grease to loosen up. If it is older you will need to make sure it has enough grease. These tools don't need a great deal of grease, but too little will soon be thrown about and disperse too much. Another problem with these is if the inner cylinder, that moves up and down to create the pressure for teh striker, has a hairline crack, it can be quite hard to see when the part is dirty. When running though air will leak out and you will loose hammer action but still have plenty of vibratiion. Another thing to check is to take the piston/cylinder and striker out and hold it facing down. The striker should slide out slow and steady. If it falls out too fast then the cylinder and/or striker is worn. You may be able to rectify this by applying a bit more grease. If it doeesn't fall out at all then there is a build of grease behind the striker causing a vacum holding it all together. You can solve this by pushing the striker in a little way, and leaving it standing for an hour or so with cleaning solvent on top. It should work it's way in and help release it. It may still need to be 'persuaded' out a bit aswell.
Posted on Oct 25, 2008
  • Stuart
    Stuart Oct 25, 2008
    One last point, if this is the same as the UK '11304 ush27' there is no piston ring that could be replced, so if the problem is wear to the cylinder/striker it would mean replacing the actual parts. Not as cheap as piston seals unfortunatly.
Replace rubber piston @ hammer rings remove all grease @ replace it thinly we call this problem dehydraulicing good luck
Posted on Jul 28, 2009
My jackhammer will not run, the cord and switch are good
Check your brushes. The brushes on the Brute breaker have a spring loaded, non-conductive pin in them. When either brush wears down far enough the pin pops out and prevents damage to the expensive armature. If by chance the brushes are OK you may have to have your armature tested.
Sep 22, 2012 | Bosch Brute Breaker Hammer 11304
Purchased a brute hammer at a garage sale and it is missing 1 of the 3 springs from the area where bits attach. Is this an easy fix and or expensive Thanks Mark
Parts are easily available for your hammer. Check on ebay or www.toolpartsdirect.com. There is a service kit available # 1617000050 that includes set of bolts, orings, grease, brushes etc. After the service kit is installed your hammer will be ready for serious work . This kit does not include springs (#3614640501 each, uses three ). Good luck ~ greatest electric hammer ever made!
Nov 10, 2010 | Bosch Brute Breaker Hammer 11304
How do I drain the gear oil from a Bosch Brute Jack Hammer
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Need to get a new wheel for the cart that holds my bosch brute breaker
you should be able to go to any hardware store with the numbers off the other wheel and buy one there. There is nothing special about them
Apr 17, 2010 | Bosch Brute Breaker Hammer 11304
Need a manual for a Bosch 11304K Brute Breaker
go to Boschtool.com and on the lower left hand side you will see a box, put your model number in there and you can download one. If you still have trouble let me know and I will try another route.
Mar 27, 2010 | Bosch Drills
Runs **** does not hammer
could be stuck striker or just worn parts from use. They make a service kit for this tool if you are handy and have the proper tools, The bolts holding this together are extremely tight. let me know if you want to try it yourself or if you need assistance to find a repair center near you. If you do I would need your city, state and zip code. Good luck
Mar 24, 2010 | Bosch 11304K Brute Breaker Hammer
Bolts snapped piston came out can i repair
should be able to, they make a service kit with new bolts and a diagram for this tool, If this is the Bosch Brute hammer the kit is 1617000426 and you should be able to buy that locally at any tool repair shop. If not let me know and I will find an online source.
Oct 28, 2009 | Bosch Brute Breaker Hammer 11304
Need to know how to take appart the bosch brute hammer gear case? Spring shaft removal technique?
You can go to Boschtools.com and type in your model number for a breakdown, but repairing this tool is a headache.
Sep 20, 2009 | Bosch Brute Breaker Hammer 11304
Bosch brute 11304 runs but does not hammer at bit end. Any advice?
Sounds like you have a broken connecting rod. The easiest way to check for this is to remove the 4 cap head bolts holding the cylinder on and remove it. If the hammer piston comes off with the clinder you should be able to see the break. If that is ok you may have some stripped gears or a broken spindle somewhere. But I really think it is the connecting rod.
Jul 28, 2009 | Bosch 11304K Brute Breaker Hammer
Bosch 15.0 Amp Brute Breaker Hammer With Service Minder Shock Mounted Handl Logo
1,181 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
