Question about GE Profile PSS26NGS Side by Side Refrigerator
G.E. ARTICA PSS26PSTASS freezes but reads wrong temperature on thermostat
2 Suggested Answers
fixyourboard
  • 310 Answers
SOURCE: Ge Artica Refrigerator PSC23PSTA ss not cooling or
Typical problems that can cause this:
- iced up evaporator due to defrost problem
- failed thermistor (temperature sensor)
- compressor not running
all of the above could be due to a failure in the main control board
there is a diagnostic mode that can help you diagnose cause
Posted on Jun 22, 2010
PSS26PSTASS
google that it was too small to hardly see!! but here is one they want paid for GE Profile Side by Side Refrigerator PSS26PSTASS Service Manual in PDF...
Apr 27, 2015 | Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Hotpoint ffp187b
The temp sensors, or thermostat may not be correctly reading the temperature. if the temp sensor reads the wrong temp for example it'll think its warmer than it actually is and keep running to try and satisfy the tstat.
Aug 05, 2013 | Refrigerators
G.e. artica freezing up
Replace the defrost thermostat located on the coils in the freezer section. Here is that part to order.
Jul 06, 2013 | Refrigerators
I have a true commercial refrigerator that the temperature is not working. It reads 11 degrees F and wont go up using the temperature control knob. Any advice?
The only thing it could be is the thermostat. Or, maybe your thermometer is reading wrong. Is everything freezing up? The thermostat is located up near the top usually on the side of the fan housing inside. It is easy to replace if you have a refrigeration supply company close by.
Sep 27, 2010 | True GDM-12 Refrigerator Commercial
I have a GE Profile Artica S/S, model # PSS25NGMD BB. The fridge side is freezing the food and the digital thermometer keeps going back to 22-25 degrees. Also, yesterday the in-door water dispenser quit...
With temperatures like that the water tank is frozen stopping water to dispenser. This could be thermistors in fresh food section going bad or a combination of thermistors and motherboard. I can assist you if you have not already called for a technician. Sea Breeze
Mar 23, 2010 | GE Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
My GE profile artica refrigerator freezer is not freezing properly. possible solutions
Bad thermostat maybe. Does it freeze up at the back ? Could also be a bad defrost timer.
Jun 30, 2009 | GE Refrigerators
Profile Artica Freezer is warming up to 32 degrees
There are 2 dials in a refrigerator. One is the thermostat the other is the air damper between the freezer and the refrigerator section. make sure your air damper is open about 1/2 way. If air does not get from the freezer to the refrigerator the thermostat might not be reading a proper temp. If you open the damper to much then you can start freezing food in the refrigerator. Some refrigerators have a opening back to the freezer down behind or beside the chrispers sometimes a paper or wraper can get down there and block air off from returning stoping the normal cycle.
I don't know if this is a solution but they are easy to check and eleminate as a possibility.
May 20, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile PSS26NGS Side by Side Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
