Tried Fn and arrow buttons as that used to work.
SOURCE: My laptop's brightness doesn't work. It's at its lowest.
Ok, I had this problem too. Go into start - all programs - samsung - Easy Display Manager, then start Easy Display Manager. Try your function key and brightness and it should work. If you cant find easy display manage this way, type it into your search and start it this way. I have mine on my shortcut menu and start it every time I re-boot now.
If none of this works, just reinstall the program from here.
http://www.fixya.com/unanswered.aspx?q=samsung+nc10
Hope this helps
Jim
SOURCE: MY SAMSUNG NETBOOK NP-N130 HAS
Try to re-enable the startup programs. You don't need that program to enable start-up items. However, you will need to do some digging to find out exactly WHAT has been disabled. Otherwise, you have no other choice BUT to do a clean install, or revert to your last backup. Those options are way more trouble than reinstalling software.
SOURCE: i cannot use my fn+f9
First of all just restart the system . Now Check if it works. Check if it works while combining it with other keys . If function keys (fn) works in that case , It should be a keyboard problem. Check all the keys . If you find any issue . Bring it to the service center and replace the keyboard if necessary
Thanks
