Question about HP OfficeJet 4315 All-In-One InkJet Printer
Hp 4315 All-In-One
Help! Unable to receive fax, sending no problem.
Thanks,
Cufflink
  • 66 Answers
try to reset the fax memory on the menu of your printer...
Posted on Oct 24, 2008
Fax will not send or receive have checked and reset fax
Make sure that phone cord is plugged into proper jack. Most faxes have line and phone...line is the proper one. Next check for dial tone.
Jun 17, 2010 | HP Officejet 4315 All-in-One Printer
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
I can not receive faxes from the hp officejet 4315 ALL IN ONE PRINTER
Do I have to be by my Hp to press answer mode to receive a fax?
Apr 13, 2010 | HP Officejet 4315 All-in-One Printer
Faxes not coming in - what do I do?
i beleive you can send faxes right but cant receive them..are u using an answering machine..make sure that u set the ring of the fax two tones higher than the answering machine..and also make sure that that the auto answer is also on in your printer..also ensure that your telephone service does not provide voicemail service..otherwise all faxes will go to voice mail..it should have distictive ring pattern..thanks
Jan 28, 2010 | HP Officejet 4315 All-in-One Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Unable to send fax
I called HP and they had a free solution promptly.
Thanks tho
Apr 08, 2009 | HP Officejet 4315 All-in-One Printer
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
HP OfficeJet 4315 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
