Question about Xerox Phaser 7760DN Laser Printer
Xerox phaser 7760dn error 1023
NO prende y dice espere por favor impresora calentado y no inicia
4 Suggested Answers
StevenC82
  • 160 Answers
SOURCE: Phaser 7760DN - won't print. Error: Close Door A
You need to check the interlock actuator ( Part#: 011E10711 ).
It costs under $20 and takes 2 min. to install a new one if it is broken, here is a video I made that shows you how.
(also works on the 7700 and 7750)
Posted on Apr 05, 2011
rajdeepdutta
  • 2517 Answers
SOURCE: tengo una impresora xeros 3100 no lo reconose el
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Jan 29, 2011
Johnnyto
  • 29 Answers
SOURCE: hola!!!! ayudenme por favor... recargue un toner
Hi. you can find an firmware fix at this link. You will find there instructions how to do it.
Posted on Feb 02, 2011
E100 error de sistema
la unidad l?ser esta defectuosa y debe ser reemplazada. si mi respuesta te fue ?til por favor h?zmelo saber
Feb 18, 2015 | Canon Office Equipment & Supplies
Tengo una impresora 7760.. se queda con el error ... calentando espere.....
Hola como estas eduardo mira la mayoria de veces es la image processing board o el engine control board. Si tienes esos componentes en mano puedes tratarlo. Tambi?n ese problema me lo a dado el disco duro pero mas la image processing board. Si necesitas partes buscanos en el iternet - iteminconline. Donde tenemos mas de 200,000 partes disponibles para tu impresora. Aqui tambien tenemos videos para mas ayuda.
Jan 05, 2015 | Xerox Phaser 7760DN Laser Printer
Como correjir error de calentando por favor y alli se queda en una phaser mfp xerox 3200
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 04, 2014 | Televison & Video
Mi impresora es canon mx 340 y me dice error 5200 que debo hacer?? ayuda por favor
You need to replace the print head.If a have been useful give me a vote.
Mar 05, 2011 | Canon PIXMA MX340 Wireless Office...
En mi imprsora lexmark me sale error 1203 cual es la solucion a mi problema gracias
El error 1203 son un asunto que ocurre o cuando un cartucho es malo o la Ranura de cartucho de impresora es mala...
1 - intenta de limpiar los contactos de cobre de la ambas ranura de carritos y carrito en la impresora y tratar otra vez.. O 2 - cuando error aparece,
cierre el poder de impresoras lejos; espere un minuto y g?relo atr?s en copia de prensa.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 25, 2011 | Lexmark X4270 All-In-One InkJet Printer
Codigo de erro 3807 como resolver?
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Feb 25, 2011 | Kodak ESP 5 Printer
MARCA ERROR 0xc18a0506 TRAE TINTAS NUEVAS :s
: Realice por favor el debajo de pasos: : 2. Apriete y suelte el bot?n de flecha hacia la derecha hasta que la presentaci?n diga "Men? de Configuraci?n de Sistema". 3. Apriete y suelte el bot?n "bueno". 4. La presentaci?n debe decir "estatus de fracaso de Hardware". Si no all? ya, Llave de Flecha sobre a "estatus de fracaso de Hardware
: 5. Apriete y suelte el bot?n "bueno" : 6. La presentaci?n debe decir "estatus de fracaso de Hardware: Vac?e. Apriete bueno vaciar". 7. Apriete y suelte el Bot?n "bueno". El mensaje cambia a "estatus de fracaso de Hardware Vaci?. Prensa Cancela para continuar". 8. Apriete y suelte el "CANCELA" bot?n como muchos veces como sea necesario, para que, o el "bienvenido a Photosmart Exprese" pantalla parece, o, el "Fracaso de Sistema de Tinta" pantalla parece. POR FAVOR no TRATE de IMPRIMIR EN ESTA ETAPA. 9. Utilizar el Bot?n del Poder, apaga la unidad y desenchufa el cable de energ?a el?ctrica de la espalda de la salida de impresora y pared.
HPRepDude: As?gurese de que realiza pasos de 2-9 y permiti? que sepa el resultado. El cliente: Visto bueno. Todo fue como si los pasos dijeron y ahora son apagado y es desenchufado. HPRepDude: 10. Espere 30 segundos para el poder de ser descargados y entonces tapan el cable de energ?a el?ctrica en la salida de pared primero y entonces en la espalda de la impresora 11. Encienda la unidad. La impresora puede demostrar mensaje "BOTON de PODER de USO Al CIERRE LA IMPRESORA" seguido por "visto bueno de PRENSA para CONTINUAR". Apriete bueno. 12. Si la impresora ya ha inicializado, entonces va al pr?ximo paso. Si no, la impresora comenzar? el "UN PROCESO de INICIALIZACION de TINTA de TIEMPO". Permita este proceso para completar y no interrumpir. Una vez que el proceso de inicializaci?n es completo, la impresora imprimir?
una P?gina Diagn?stica. 13. Para verificar impresora funcionalidad imprime una AUTO PAGINA de PRUEBA. : Realice por favor todos los pasos antes mencionados de 10 a 13.
Nov 24, 2010 | HP Photosmart C6280 Printer
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ┬┐Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
Xerox Phaser 7760DN Laser Printer Logo
188 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
