Question about Philips Televison & Video
How to unlock child lock on sharp tv without remote
Activated childlock on scart channel through Menu on TV by mistake but don't have the remote to unlock. Please help!
SOURCE: tv is stuck on av channel
no-not the tv try buying another remote from the manufacturer and that will solve the problem
Posted on Aug 31, 2007
snakehead
  • 1074 Answers
SOURCE: child lock on
the only way you can get out the child lock is to unsolder the eeprom and solder it back. this will deactivate the code that was entered.good luck.
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: sharp 19"color tv
change the electrolytic capacitor in the high voltage section.and check the continuity if there are open resistor.
Posted on Sep 07, 2008
mumma_1
  • 903 Answers
SOURCE: harwa tv childlock code
http://www.retrevo.com/s/RCA-27F520T-TVs-review-manual/id/402ci358/t/1-2/
TRY HERE FOR THE MANUAL. HOPE IT HELPS
Posted on Oct 26, 2008
SOURCE: 27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
i need the answer for this problem i have a 27" tv and the original remote is lost. recently hit child lock on mistake through tv buttons. now cant turn tv on. tried a universal remote but unable to get tv to respond
Posted on Nov 23, 2008
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Tip
How to Unlock Your Apex TV When Screen is Locked
If you find that your Apex TV is showing a blank screen with a red key on the bottom left then the Screen Lock otherwise known as Child Lock or Parental Control has been accidentally activated and your TV will not respond to commands from the remote control.
To resolve this and reactivate the TV simply press the (function or F) button and hold down the mute button on the remote at the same time for around 10 seconds. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or to reset any preset rating levels.
This extract is taken from an Apex Manual specific to the child lock function;
The Childlock function is designed to prevent chiIdren from watching TV. To activate: HoId down the F button and then press the MUTE button until the symboI “ ” appears on the screen. The TV will enter the Childlock mode.
Except for the “ ” symbol the screen becomes blue or black . To unlock the TV hoId down the F button and then press the MUTE button again.
Please Note:
The Childlock can be set or cancelIed only by the remote controI. After setting Childlock, secure the remote control in a safe place.
If this Tip has helped please do take time to indicate this by using the rating buttons on the page below.
Many thanks for using FixYa.
on Dec 17, 2009 | Televison & Video
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
Alba hd tv, no remote and the child lock is on just need to bypass it model no lcd3288ohdf
Okay - this is a secret child lock that Alba puts onto their tvs - not the child lock accessible via the menu which is 0000 as default. Basically there is a childlock built into the handset. Basically if you hold the menu exit button for more than 10 seconds the handset locks - all that happens then is when you press buttons you will see the blue panel flash on the tv but nothing works. This lock happens when the remote falls down the side of the settee or your child gets their hands on it!!! To unlock, find the menu button on the right hand side of the TV panel and hold it for 15 seconds and the menu screen will pop up - Really important you hold for 15 seconds before releasing. Then simply press the menu exit button on the remote and 'hey presto' - you have control of your TV again! Kind Regards, BIG BAD JON !!!
Oct 31, 2010 | Televison & Video
Chuld unlock
to unlock the parental control on a Telefunken TV that has a blue screen and a red padlock on the top left hand side, hold down the display button on the remote for 10 seconds and it works
Sep 02, 2008 | Televison & Video
Child lock to unlock
YOU WILL NEED THE DEDICATED REMOTE CONTROL
Jun 13, 2008 | Televison & Video
Un lock child Lock.
HAL DIE EPROME YT SIT AN TV VIR EEN SEC EN SIT EPROM TRIG EN SIT TV AN
Jun 13, 2008 | Akira EPM-420A 42 in. Plasma Television
Unlock childlock sansui sv-t21pa2s
hi
how to open child lock for this sansui tv
Feb 29, 2008 | Sansui DTV2760 27" TV
Child Lock Aiko TV
I had the same problem with an AIKO TV. The childlock was on and initially I couldn't find the remote after moving. Unfortunately the only way I got it unlocked was with the remote. So I turned the TV off with the remote. Then turned it back on and then had to go into MENU and change child lock from on to OFF. Sorry no other handy suggestions if you haven't got the remote.
Dec 08, 2007 | Haier HTF27R11 27" TV
Permant child lock
Sorry man The only way I know to unlock it is with the original remote. They are available at http://www.remotes.com You have to press the M or Mute button and the F or the Function button at the same time. If the remote you have has these buttons try them. Like I said if it doesnt work, you will need an original remote. See if anyone you know has one you can borrow or the store where you bought the TV, maybe they will let you borrow one. Good Luck
Aug 12, 2006 | Apex Digital PF2020 20" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
