Question about Radio Communications
Yaesu FT 900 will not power up
The radio, first started cutting off. when turned back on, it stay on for a few seconds, then power off, now it will not power up at all when the on button is pushed.
  • 518 Answers
SOURCE: Yaesu FT-50R battery drain
I have the same radio.
Does the radio work? Could it be the battery that's getting hot?
Geno
N8BHG
Posted on Feb 20, 2008
vrc_tech
  • 109 Answers
SOURCE: Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
Posted on Aug 21, 2008
SOURCE: Operating The Yaesu FT-767 GX
hello this borja from spain.
i have all manuals of this radio even the schematics
email me and i,ll send you back all info caramelovetense@hotmail.com
Posted on Dec 27, 2008
SOURCE: Yaesu FT 11R
figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
Posted on Jan 10, 2009
SOURCE: Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Posted on Apr 07, 2009
My radio cuts out completely. Wait ! minute and repress the power button, radio back on.
sounds like the power supply. Check all your connections and wires just in case. But it REALLY sounds like the power supply.
Mar 06, 2015 | Yaesu FT-990 DC Transceiver
YAESU FT 8800 WILL POWER UP AFTER USING CHIRP PROGRAMING
it sounds like you loaded corrupt data into the memory registers or god forbid, let the magic smoke out of the CPU, and we all know with out the magic smoke it wont work anymore. disconnect the programming cable plug the mic back in and pull out the owners manual and look up how to do a factory reset, and perform one EXACTLY as instructed. if this doesn't fix the issue the radio is going to need service. You don't mention if you used a factory cable or after market programming cable. Ive never used Chirp software, so I cant comment on it, in fact, Ive never heard of it before and I run Yaesu equipment in my mobiles and for my handhelds.
Sep 28, 2014 | Yaesu FT-8800R VHF/UHF Dual Band Mobile...
Software Menu Aligment yaesu FT-857
http://www.hampedia.net/yaesu/ft-857-second-menu.php this link lists the settings to put back to factory abc together when switching on to access
Apr 10, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
Yaesu FT-8900 will not power up
You've prbably answered your query yourself.
Having said that, try joining yahoo group specifically for the FT-8900, they will have more info for you.
Cheers,
Peter
Mar 02, 2013 | Yaesu Radio Communications
Yaesu FT-100D transmit problem
has it been opened up to talk on
Dec 17, 2009 | Radio Communications
Yaesu FT-11R amateur radio squelch problem
It sounds like perhaps you have CTCSS turned on so it's blocking received signals that aren't using sub-audible tones. Make sure the "TSQ" indicator is not showing. Most Yaesu radios have the SQU or "T.SQ" option easily found in their menu structure..
Nov 12, 2009 | Vertex FNB-38, YAESU,FT-11R,FT-41R,FT-51R,...
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
After factory reset of yaesu vx-5 can not get out of nfm
Check the frequency step setting. If you have it set to 12.5kHz it's possible that's forcing the nfm mode.
Dec 26, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT 11R
Sep 28, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Radio Communications Logo
199 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
