Question about Beko Washing Machines
Keeps blowing the fuse
Beko wmb 10w when machine is switch on blower main fuse in house was working fine for two years could it be suppresser
  • 53 Answers
SOURCE: Candy GO1482 washing machine blows house fuse
This sounds like an electrical fault within your Candy washing machine.
Have you tried plugging your coffee machine, dishwasher or toaster into the SAME POWER SOCKET?
If so, does this still trip out the mains/house fuse?
If it does, it sounds like there is a fault in your house wiring.
If these "high power" devices/appliances do not cause the same problem, then you may have an Earth Leakage fault on your washing machine or something else inside it has short-circuited and will need servicing right away!
Posted on Nov 18, 2009
  • 2468 Answers
SOURCE: My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
Posted on May 14, 2010
SOURCE: Beko WMA 10W
MY WASHING MACHINE WILL NOT SPIN BUT IT DOES EVERTHING ELSE
Posted on Jun 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: hi i have a beko wma 10wdoesn,t let the water into softner compar
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
SOURCE: Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Posted on Dec 05, 2010
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
Beko washing machine
turn off power and check to see if fuse blown (for the motor) on the internal circuit board (if it has one). You will probably need to remove the cover. If you are lucky you might be able to turn the machine on its side to gain access through the bottom to any fuses ? Get help when lifting heavy objects.
Dec 30, 2013 | Washing Machines
I have a beko wmb washing machine that stops working as soon as its put on and then the wash and ready lights start flashing... what could be wrong?
Try reading the "troubleshooting" section of the instruction manual. If you don't have the instructions, go to the Beko web site and download them.
Oct 21, 2013 | Beko Washing Machines
Hi. my BEKO condensor sensor dryer cuts out the electric mains flip switch when i turn it on. Have checked the fuse and lead no damage, checked socket and it works other appliances. What would cause t
The same happened to our Beko DCU8230 last week still under 1 year warranty, loud bang, burning smell and trip switch flipped. Beko Engineer who called said mains suppressor capacitor had blown.
Aug 27, 2012 | Dryers
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
2000 Wrangler blower won't work
HOT WIRE BLOWER MOTOR IF IT WORKS PROBLEM IN THE BLOWER RELAY AND RESISTOR.IF BLOWER DONT WORK REPLACE IT.
Sep 02, 2009 | 2004 Jeep Wrangler
Washing Machines Logo
23 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
