Question about Panasonic PT-51G63 51" Rear Projection Television
PT-51G36E Convergence Problems
Bows in at top, bottom, and sides. I have replaced both convergence outputs, and checked all the resistors. seems like some kind of a pin cuision problem.
  • Terry White Aug 08, 2006
    Techman, yes I do have a service manual.The tv is actually a PT-51G36E...with the same symptoms...
    President:
  • 3,130 Answers
Did you get a schematic? Though so!! If you want to work on a TV set Do it like a professional .. Get a schematic.. this way when you have a problem your not shot gunning the repair as your doing now.. If you get a schematic man I will be more then happy to assist you with this repair. Good Luck
Posted on Aug 08, 2006
    New Friend:
  • 163 Answers
Did you check power supply capacitors? may be is a pincushion but check cap first... good luck
SOURCE:
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I cannot get the blue convergence cross to line up with others.
The tv convergence board is dead.Any colors G,B,R don't alignment matches up.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Dec 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Green rainbow streak on bottom of TV PT-47Wx49E
If Convergence on setup dosen't work, And you think its not STK Convergence chips!, Then "Yes" It more then likely will have a few open Resistors!... (Near STK chips)
Jun 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence
You need sevice code to enter convergence.
Mar 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Green Bows on top and bottom
This is most likely either bad connections on the convergence IC or a defective IC. Try resoldering the pins first. If that fails to resolve the problem, replace the IC.
Dan
Mar 18, 2008 | Panasonic PT-53WX53 53" Rear Projection...
50P8341 red bows
Convergence ICs or the resistors powering them are bad. Check for open resistors near the ICs if any are open, change both ICs and the resistors.
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
PT-53WX52
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 02, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-51G63 51" Rear Projection Television Logo
175 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
