Question about Hunter 28190 Charmaine Antique Brass Ceiling Fan
I have a Hunter 28190 Charmaine Antique Brass Ceiling Fan, the remote has never worked.
I have a remote that has never worked for my Hunter 28190 Charmaine Antique Brass Ceiling Fan. The remote part no. is 85752. I tried the fix of syncing it by pressing the 3 speed button, then the 2 and then holding the 1, until you hear a click, but no sound is made and it doesn't fix it.
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
SOURCE: Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Posted on Jun 18, 2009
  • 7 Answers
SOURCE: Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 4 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
It's a 3-speed ceiling fan that's for sure. I think the same a fixer1950 already said...
This page about <a href=http://www.ceiling-fan-wizard.com/hunter-ceiling-fans.html>hunter ceiling fans</a> might be interesting...
Posted on Oct 09, 2009
How to sync the remote with the fan?The remote was operating the fan, but someone must have pulled the chain on the fan.
I have a ceiling fan that fails to operate under remote control whenever a power outage occurs. The solution is to pull the chain to guess which is an ON position, then operate the remote to select fan speed or off. Same routine for the light, if there is one.
Sep 04, 2012 | Hunter Fan Company 20184 H 52" Antique...
Remote control is not functioning properly. Will turn on, using "high speed" button, but then drops to "low speed' wil no rmain on 'High speed"
the receiver in the fan is going out, they do all the time with remote set ups, also remember that if the fan has been wired through a wall switch,, this will hinder the remote from working properly
Jul 08, 2011 | Hunter 22435 Sontera Antique Brass Ceiling...
Fan Model CP 943OR--remote will not turn fan on
Check for dust or film on the pickup sensor on the fan itself.
Jun 13, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
How do I replace the light pull chain that broke off inside the base of a ceiling fan?
You will have to replace the entire switch. The switch is held in by the collar that the chain (used to) comes through. It just screws off. Then you have to twist off the wire nuts for the switch wires inside the light fixture part. Did I mention to make sure that the electricity is turned off before you do this? The switch is available at most hardware stores.
Jun 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Blade problem
The Hunter web site should have them. If not I have found simular ones at Radio Shack and also have ordered them from parts suppliers like Mouser, Digi-key, Allied electronics Mat electronics. All of which can be found and ordered from online.
Jan 29, 2008 | Hunter 22435 Sontera Antique Brass Ceiling...
Two fans, remotes work with one, not the other
YOU MUST TRY CHANGEING THE CHANNEL ON THE REMOT AND TRY IT THEN IF IT DOES NOT WORK YOU MUST TAKE DOWN THE FAN AND CHECK WHAT CHANNEL THE RECIEVER HAS AND MATCH IT TO THE REMOTE.
Nov 04, 2007 | Hunter Vaulted Ceiling Mount - Antique...
Hunter 28190 Charmaine Antique Brass Ceiling Fan Logo
55 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
