Question about Brother DCP-7020 All-In-One Laser Printer
Back Door Open on Brother DCP-7020 printer
Display indicates that the back door is opened. I open and close the back door but the message never goes away. I have checked for pieces of paper that maybe jammed but I can not find any. I have looked for a mechanical switch, etc., but cannot locate one if there is one. I have removed the drum and toner cartridge but that did not help.
Can someone please suggest what else I can look for? This is driving me nuts. I tried to find a service and repair manual for this printer but I haven't been lucky.
  • 3 more comments
  • JINA125 Oct 31, 2008
    I'M HAVING THE SAME PROBLEM..DOES ANYONE KNOW HOW TO FIX THIS??
  • desertgas Nov 10, 2008
    have same problem, with back panel warning, even though is seems closed
  • gary474 Mar 24, 2009
    I have exactly the same problem, is there no solution to this problem?
  • Anonymous Apr 24, 2009
    Same problem
  • Anonymous May 21, 2009
    same problem - no apparent reason - bad design
I opened the back panel and yanked out the piece of paper that was apparently halfway through the machine. Message dissapeared, printer warmed up and I could print again. This would appear to be a poorly designed error messaging system that wasn't properly tested.
Posted on May 21, 2009
BACK COVER OPEN
The back cover sensor is detecting the back door is opened. Open and close the back door firmly to fix this message.
Aug 22, 2012 | Brother DCP-7020 All-In-One Laser Printer
My Brother DCP 7020 won't stop flashing close back door
There's a micro-switch that "trips" when the door is opened/closed. It's not sending a "closed" signal to the printer. Clean the switch, with a blast of compressed air. Check that a small "finger" is going-in to the slot, to "trip" the sensor, as the door is closing.
May 07, 2010 | Brother DCP-7020 All-In-One Laser Printer
Back Door is open. Printer will not work. Keep
The black flap inside the rear door has a sensor flag mounted on it. The flag goes thru a hole on the side. If the spring is missing or broken or the flag is missing or broken, the error will persist.
Jan 06, 2010 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP 7020 display reads "Drum Error" and instructs me to clean corona wire which I did. I then bought a new drum and still get the same message.
You need to reset after a new drum, open the front door and press menu or options and it will ask if it's a new drum. after that if you still have the error, you may need a new power supply PCB.
Dec 29, 2009 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Back door open alert
Twist the printer so that you can see the back of the printer.
Near the bottom, there is a door that swings down.
Swing it down and it will open (get familiar with it). Then close it. There is a magnetic catch.
Oct 05, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother dcp-7020 printer shows error back door open.
open the front door then pull away your ink cartridge then clean dust or blur from ink cartridge position then refix ink cartridge again.
Mar 21, 2009 | Brother DCP-7020 All-In-One Laser Printer
Reset Drum
Take it out and put it back in - the trick is to LEAVE THE FRONT DOOR OPEN after you put it back in. With the door still OPEN push the "options" button and you will be prompted for "New Drum?" and then push the "Up" button for 'Yes' and "Accepted" will appear on the lcd screen - and then the drum counter will be reset. The directions in the book work great - but you have to be careful make sure the door is still open when you push the "options" button...
Jul 16, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
402 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
