Question about Panasonic PT-47WX49 47" Rear Projection Television
The screen that on front of the TV
On my tv, the screen that is on front of the TV needs replacing. I have scratches and a crack on it . If it can be replaced, about how much and where can I get it from?
    Genius:
  • 2,920 Answers
You woeuld need to order the screen from whoever makes the tv and it can be very expensive
Posted on Oct 26, 2008
I need a panel for LG42LN5400,i cracked it,what the price for 1?
You can Google Replacement TV Screens to get the price. It's a huge job to replace the screen. Every part inside the TV has to come out Then the bezel has to be separated. That requires special tools to prevent marring and scratches. Best left to a pro.
Jul 05, 2015 | Televison & Video
Cracked front glass
U out of luck,not worth to replaced the screen,the screen it same as the new tv.The tv compannies sell out tv screen as a new tv.The tv 95% worth is in the screen.
Dec 23, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Projection TV Screen is scratched/Speakers Don't work
u can buy new screen toshbia.com tv parts sears.com tv parts cost i have replace 1 before screen 300 bucks be very careful glass extremly thin thin will crack good luck
Aug 06, 2009 | Toshiba Televison & Video
Screen has a little scratch there is sound but on picture with little thread lines coming form the scratch
you likely need a new tv. on the insides the audio pieces are a lot tougher than the delicate pieces that create the picture for you. if it was dropped and something hit it and it cracked losing your picture, I am pretty sure the tv is toast.
May 19, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony 57" projection TV - need replacement screen
The part number for the screen for the KP57WS500 does not match the one for the KDP-57WS550. The inner screen is still available for the KDP using part number 4-095-924-01 for $120.32
Hope this helps,
Dan
Mar 23, 2009 | Sony KP-57WS500 57" Rear Projection...
I have a 3 inch scratch on my plasma tv that happened in a move. I think it is a glass screen. Is there any way to cover or fill this scratch. It isn't very deep but it bugs me that I can see it.
You must determine whether or not the scratch is on a protective fromt screen or the panel itself. I don't know your specific model, but some of the LGs have a front glass behind which is the actual panel. If that is the case with yours, you can replace the front glass. If it is only the panel, then there is no way to repair other than replacing the panel which is VERY expensive.
If you wish to try something, go to a local auto parts store and purchase a windshield repair kit. This will contain an optically transparent epoxy that can fill in the scratch and make it at least less noticable similar to filling a scratch or crack on a windshield.
Dan
Mar 06, 2009 | LG 30FZ4D TV
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Scratch
hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Nov 29, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Scratched lcd screen
nope...once scratched, it's like those spider web cracks in a windshield..better to plan on a replacement in not too distant future..
Feb 22, 2008 | Samsung Refurbished Elec 13.3TFT SCREEN -...
Panasonic PT-47WX49 47" Rear Projection Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
