Laurex Prestige displays scientific notation - Office Equipment & Supplies
  • 56 Answers
SOURCE: scientific notation
you want to hit mode not menu and then make sure that normal is flashing instead of SCI and hit enter. so just hit mode then enter and it should be normal
Posted on Jan 14, 2008
SOURCE: HOW TO USE SCIENTIFIC NOTATION
z=e over i z= 480 over0.6 z= blank
Posted on Feb 18, 2009
  • 1606 Answers
SOURCE: how to convert a normal ANSWER to scientific
It's been a while since my TI calculator died, but I think you can just hit EE (may be "exp" on your model) followed by =.
Posted on Aug 28, 2009
  • 8068 Answers
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Posted on Sep 17, 2009
  • 8068 Answers
SOURCE: how to turn off scientific notation?
Press [SHIFT][MODE][6:Fix] (number between 0 an 9) to select the number of decimal digits you want. Then press [=].
Hope it helps.
Posted on Oct 09, 2009
My calculator will give me an answer in scientific notation. How do I change it to decimal form?
To switch out of scientific notation, press SHIFT MODE then select Fix or Norm.
Be aware that the calculator will switch to scientific notation anyway if the magnitude of the answer is too large or too small.
Aug 24, 2014 | Casio FX-115ES Scientific Calculator
Scientific notation
All calculator use scientific notation if the result is too small or too large. Some, like the Casio FX9750G II, offer you two Normal displays, Norm1 and Norm2 that have different limits when numbers are converted to scientific notations.
Here is how to set one or the other.
In Run>Mat press SHIFT MODE (Setup). Scroll down or up to reach the display line. Press F3 to select Norm1 or Norm2.
Oct 22, 2013 | Casio FX9750GII Graphic Calculator
I want to remove the word fix from the top of the calculator
You've got the display set to fixed decimal notation. To change it, press SHIFT MODE 7 to switch to a scientific notation or SHIFT MODE 8 and then 1 or 2 to switch to one of the norm display modes.
norm1 switches to scientific notation if the magnitude of the number is less than 0.01 .
norm2 switches to scientific notation if the magnitude of the number is less than 0.000000001 .
Jun 07, 2011 | Casio FX991ES Scientific Calculator
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Feb 13, 2011 | Texas Instruments TI-30XA Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
Apr 16, 2010 | Casio fx-300ES Calculator
Scientific notation when not wanted.
Unfortunately, you don't. For numbers whose magnitudes differ too greatly from 1, the calculator automatically switches to scientific (or engineering) notation. You can press MODE and change the display settings, but there is no setting that will force the calculator to show this number without an exponent.
Feb 25, 2010 | Texas Instruments TI-83 Plus Calculator
HP 12C went into scientific notation and will not come out of it
To exit the scientific display format press the [f] key followed by the number of decimal digits you want.
Hope it helps.
Oct 31, 2009 | HP 12c Calculator
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Aug 24, 2009 | HP 12c Calculator
60 people viewed this question
k24674
jasbo
jasbo
