Question about Ricoh Aficio 1085 Laser Printer
Ricoh 1018d not print with lan conection
Ihave a problem with conect 1018d with computer to print with lan conection i inter true IP for the mach. & computer and i use pcl6 driver
and the machin give replay in pinging but not print
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Posted on Jan 23, 2009
Ineed to open port 22 so my son can work on my computer from a remote location,but the tech ao twin lakes telephone has no idea what l am talking about . Can anyone help me?
first u go to setup page ip :- passand then go to services if ur port is not on the firewall rules.add ur port in services and name it then go to firewall rulesand now add the name of port which was added in services or if already present just enter that and in action enter"allow always"last thing to enter is ur pc ip in " send to lan server like something" eg:- this is my pc ip,it would be like this only 192.168.0.xxdone.And always off the incoming port because it can dangerous if port is left open.
Feb 17, 2012 | NetGear WGR614 Wireless Router
Hii i have richo c2530 printer and i change my pc now when i conect the printer with lan port it gives yelow colouer in network even i conecet usb prot and when i print somthing it gives me eroor info...
If you change the conections to the machine you need to change the port of the driver.
For exemple: If your machine is conected by TCP/IP you need to put the correct port in the driver properties.
If you conect to USB you need to chenge the port in the driver properties to the USB option.
If you have any doubt reply to me. I will be glad to help you
See you!
Sep 24, 2011 | Ricoh Aficio 2035 Copier
My ricoh aficio 3025 copier has the capabilities to scan, print & fax but it only copies. Can we add those modules?
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Jul 09, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
My Samsung printer is conected on other computer,and not printing
try to reinstall printer driver.
Be sure printer IP adres is correct.
Good Luck!
Jun 21, 2010 | Samsung ML-2251NP Laser Printer
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
HOW to configure ricoh aficio 2032 on nework and install it on more than 1 pc. this printer is connected via ethernet cable to dlink switch, where my other pcs are conected. but i cant connect it on any...
You install driver for the Aficio 2032 on all computers where you want to be printed from it.
Then you will go to Printer driver properties and then need to be created port TCP/IP and write the address from the printer it's same as connecting a computer on network
Jun 30, 2009 | Ricoh Aficio SP C210 Laser Printer
Toshiba E-Studio 160 network print?
Go to Control Panel -> Printers. Select Add Printer... When it prompts for a local printer or a network printer, select network. Follow the prompts from there.
Mar 29, 2009 | Toshiba E-Studio 160 All-In-One Laser...
My Ricoh Laser Printer is not working
For to use the network printer first of all you should have a network connection port.
If you have one on your printer than you should install a driver on the computer from where you will print then connect the cable with network LAN cable which the one end is connected into the printer and the other into the network switch or router. After this is done go to start menu on you computer than go to printers and faxes and select the printer driver 1515 press the right click and click on properties then go to port and create a TCP/IP port similar to the computer ip address.
if the address on the computer is
than put the address of the printer as follow
Please look at the paper sheet which is printed from the machine by her self when the machine is turned on for the first time in the day.
There should have a port name which can be 10001 or 9100 or 9101 or similar.
Enter that number in the TCP/IP port properties than go to the machine and press the [User tools/ Counter] key then go to system settings and than network settings and enter there the ip address which you had enter before on the driver in the computer.
Jun 02, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
Ricoh Aficio 1085 Laser Printer Logo
238 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
