Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
Where is the float switch on a bunn stf-15 - Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
3 Suggested Answers
  • 124 Answers
SOURCE: Bunn-O-Matic Model STF 20 is making loud noises
You may have a thermostat problem.
Contact a Bunn service center and have the unit checked.
Posted on Jan 03, 2010
EsWorld
  • 1618 Answers
SOURCE: I have a Bunn Model STF-15. Water fills then
If the solenoid is working properly then the float switch for the brew volume needs to be cleaned because it might have some build that weighing it down.
Posted on Nov 26, 2010
I have a bunn CW series brewer. I filled the reserve with water and allowed to get hot. I then add additional water (1 glass pot) and it just starts to dispense without me hitting the "start" button. I...
Sounds like the switch is stuck in the operate position. Therefor once the machine hits temperature it just brews. Your local Bunn distributor should be able to recommend an engineer to replace the switch or supply the correct t,hope of switch if your confident enought Tom replace it yourself.
May 11, 2014 | Bunn CW 15-APS Coffee Maker
Water is not hot when turn on
check the heat switch in the rear. if it's on, check the thermal fuse in the top right rear of the brewer. it'll be in a now browned tubing. you can get it through bunn (800) 352-BUNN (2866)
Jan 05, 2014 | Bunn CWTF 15-APS Coffee Maker
What is the best way to clean a Bunn STF-20 coffee maker. It has a water line connection,
Clean with white vinegar, run it through 3 times, then you are set.
Oct 09, 2012 | Refrigerators
COFFEE MACHINE KEEPS FIL;LING UP AND OVERFLOWS. tHIS IS A BUNNOMATIC MODEL STPF-15
Dunkin Donuts decaf coffee clogs the filter as the water fills the basket causing the basket to overflow. The coffee is ground too fine. Swtich brands or use a second filter to cover the coffee grounds to keep them from floating and clogging the filter.
Feb 24, 2011 | Bunn A10 Coffee Maker
CWT 15-APS Coffee Maker: How do I get into the back of a CW series brewer t...
You have to get to it from the front panel. Remove the 6 screws for access.
May 18, 2010 | Bunn CWT 15-APS Coffee Maker
Bunn-O-Matic Model STF 20 is making loud noises and spewing water after brewing is complete
Nov 07, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
I BOUGHT A USED BUNN COFFEE MACHINE STF-15. IT CAME WITH THREE POTS THAT HAVE THE NAME ELLIS COFFEE ON THEM. PART #2097 0202. WHEN I RUNS IT THE POT OVER FILLS. DO I HAVE THE WRONG POT OR IS THERE AN...
This is usually the result of an incorrectly set timer (see p. 22 & p. 24 of manual) or stuck solenoid valve (p. 18). A link to the owner's manual is provided below. You should read the manual thoroughly before attempting adjustments & repairs.
http://www.bunn.com/pdfs/commercial/manuals/29251.0000.pdf
I hope this helps!
Oct 20, 2009 | Coffee Makers & Espresso Machines
Set flow amount on Bunn STF 35
Remove the top panel and look for the yellow float, this controls the amount of water brewed, to adjust remove some of the washers on the float and test until you get the amount needed.
Jul 24, 2009 | Coffee Makers & Espresso Machines
I have a STF-35 , brews more then the pot , can you adjust the amount of water per brew ?
Yes, but you need the pre weighed grommets from bunn, if you remove the top panel on the machine you will see the brew tank, within that there will be brown plastic shaft with a yellowish cylinder on top of it. There might be 3 or 4 washers on top of that yellow piece, those are the weights, when the water fills the tank it pushes the float up and when it reaches the top it turns off the solenoid. You should be able to try it without the top on.
Jun 24, 2009 | Coffee Makers & Espresso Machines
On-Off light not working
My coffee maker is about 15 years old. The on and off switch works but the light does not. Is there a way to replace the bulb.
Than You
Judith 54
Sep 08, 2008 | Bunn NHB Coffee Maker
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
50 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
