Question about Dell 5100cn Laser Printer
Dell 5100cn paper not stacking in the top output tray
I have a Dell 5100cn that is having a problem with paper not stacking properly in the top output tray. Every few pages, there will be a page where the bottom of the page hasn't fallen completely into the output paper stack and the top of the next page will hit it and push that page off the printer or make it not stack neatly. Is it a problem with the rollers (possibly the set of rollers at the output tray) ? If so, what is the part # to order?
Thanks !!!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Hi mcres,
I believe that I addressed this issue on the repeat post you made on 10/27/2008.
the following is the answer I posted there
I am attaching a photo for reference of the outer duplexer assembly of the 5100 printer.
This the area just to the right of the yellow arrow is what moves the paper from the exit of the fuser to the top output bin. ( it also brings the paper back in when duplexing ).
Those are the rollers that I believe you are questioning, however, this unit is an assembly, and those rollers are not replaceable.
I can tell you however, that I have never had a situation that required those rollers to be changed.
What I would suggest is that you clean the rollers with a lint free cloth and rubbing alcohol.
Also check the printer while printing and try to observe that it is not actually the front edge of the paper coming out getting hung up on something ( even a small bur on the plastic ) that may be preventing it from exiting all the way.
Posted on Oct 31, 2008
When I send something to print the right hand side of the paper comes out all crumpled up, as if there is something stuck that it can not pass. I have looked in the printer but can't see anything. When...
Issue
While printing, the printer paper is torn, ripped, wrinkled, or damaged.Solution Follow these steps in the order presented to resolve the issue.Step one: Remove all paper from the input and output trays Remove all paper from the input and output trays on the product.Step Two: Check the paper path for obstructions Press the Power ( ) button to turn off the product. Verify the input tray is empty, and then check for paper jams, bits of paper, and other obstructions, gently removing any obstructions.Lift the top door or the front cover, depending on the product, to access the print carriage, and then check for any obstructions in the paper path.Gently remove any paper or other obstructions from the paper path you might find, and then close the print carriage access door.Open the rear access door.Gently remove any paper or other obstructions from the paper path.Check the spring-loaded rear access door rollers to verify that they are clean and can be rolled.check the paper rollers inside the rear access and verify that the rollers are clean and roll upwards.Check the star wheel assembly inside the printer on the output side of the carriage. Verify that it is in good condition and clear of paper bits or other obstructions. NOTE:The star wheel assembly is located inside the printer on the output side of the carriage. The star wheel assembly is a set of small, star-shaped wheels on top and rubber rollers on the bottom. The assembly grips the printed side of the paper, and moves the paper to the output tray after printing.Replace the rear access door and verify that the rollers on the door and the rollers inside the rear access of the product are "matched up" with each other.Press the power button to turn on the product.Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include: Plain paper, 20 to 24 lb (75 to 90 gsm) Legal size paper, 20 to 24 lb (75 to 90 gsm) Card stock, up to a maximum of 110 lb (200 gsm) Envelopes, 20 to 24 lb (75 to 90 gsm) Photo paper, 145 lb (236 gsm) NOTE:Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.Step Four: Make sure that the paper is loaded correctly Gather a stack of plain, white paper and load it in the product's input tray.Use only one type of paper in the stack.Use 10 to 25 sheets of paper in the stack.Fan the stack of paper to make sure that the sheets do not stick together. Tap the stack of paper against a hard, flat surface, such as a table top, to make the edges even.Insert the stack of paper into the input tray.make sure that the stack of paper is flat in the input tray. Verify the right side of the stack of paper touches the right side of the input tray and that the stack is pushed completely into the tray.Position the paper guides firmly against the sides of the paper stack without bending the paper.Step Five: Test the All-in-One Follow these steps to print a self-test page. If the page prints successfully, the product is functioning correctly.Press the Setup button on the printer.Depending on what product you have, perform one of the following:Press the arrow key to select Print Report and then press OK.Press the arrow key to select Self Test eport and press OK.A test page prints.If the test page prints without damaging the paper, you do not need to take any other action.If the test page is damaged during printing, proceed to the next step.NOTE:For printers which do not have a Setup button, check the product documentation to find out how to print a self test page.Step Six: Contact HP If you have completed all the steps listed above and are still experiencing a problem, the rear access door or the star wheel assembly is likely damaged. To replace the rear access door, contact HP. If the star wheel assembly is damaged, replace the product.Cause There are several possible causes: Bits of paper might be obstructing the paper path and need to be cleared.Unsupported paper types and sizes might catch and tear in the printer mechanism while printing.Paper pushed too far into the input tray when it is loaded, might feed into the printer incorrectly, causing the paper to tear.Paper stacks loaded into the input tray with too many or too few sheets of paper, might feed into the printer incorrectly, causing the paper to tear.Paper stacks that are not properly stacked when loaded into the input tray, might feed into the printer incorrectly, causing the paper to tear.The rollers on the rear access door and inside the product's rear access might not be clean, in good condition or freely rolling.the star wheel assembly might be obstructed or have damaged or missing parts, causing the paper to tear.The rear access door might be damaged.The wheels on the star wheel assembly might be damaged.
Oct 12, 2011 | HP Officejet J5780 All-In-One InkJet...
Where is the manual paper feeder tray?
The manual feeder is located at 4 on this webpage. I would say its in the front. but a picture is a lot better. then how I would describe it.
http://support.dell.com/support/edocs/systems/5100cn/en/UG/index.html
Jun 17, 2010 | Dell 5100cn Laser Printer
Dell Laser Printer 5100cn Load MPF Letter Plain 1 !
Are you trying to use the "MPF" (Manual Paper Feed) tray?
If you are then the manual paper feed tray is usually a fold down flap at the back of the printer. It only accepts on piece of paper at a time.
However, if you are just trying to print to the printer's default tray, then you need to check both the "Page Setup" in the application and the printer driver properties to make sure that you are calling the correct paper tray.
Don
Nov 18, 2009 | Dell 5100cn Laser Printer
5100CN ask to load paper in tray when tray is full
There should be a plastic flag that hangs down into the tray. When the tray is full the other end of the flag moves out of the path of an inferred sensor. Locate the sensor and try cleaning it.
Dec 02, 2008 | Dell 5100cn Laser Printer
Dell 5100cn won't recognize mpf tray
Go to the printer web page by entering the IP address of the printer in an Internet Browser.
click Printer Settings menu entry
If the Substitute Tray value is not MPF Feed, click on the Printer Settings tab
Set the Substitute Tray value to MPF Feed
Click the button Apply New Settings, it will request the admin id & password for the printer.
In trying to resolve this issue, initially I set the Tray Settings to Panel Specified from Driver Specified at the printer's panel. Since the issue was resolved with this set, I just left it that way.
Nov 01, 2008 | Dell 5100cn Laser Printer
5100cn paper not stacking correctly in output tray
Hi MCRES,
Oct 27, 2008 | Dell 5100cn Laser Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
Error Message on Dell 5100cn
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
