JBL DCR600 blows fuses - Audio Players & Recorders
2 Suggested Answers
SOURCE: JBL PSW-D112 Speaker fuse blow immediately after replaced
The Problem in this unit is the Amplifier module S64AMI,which is surrended in a black heatsink, filled with epoxy, not serviceable, the bad news is that JBL discontinued this module and is really hard to find, sorry....
Posted on Nov 21, 2009
JBL subwoofer not giving sounds even it is correctly connected
If this is a powered sub, than it will have it's own power supply and small mono amp, both of which can fail. Could be a fuse, but if the fuse blows again you will have a short on the main amp board.
Nov 20, 2015 | JBL Audio Players & Recorders
Jbl subwoofer fuse
there is a short in the amp that would need to be fixed before the unit will power on
Dec 12, 2013 | Audio Players & Recorders
Remote for reciever not working
we can check our remote controls the simplest way.. provided you have your cellphone with camera turn it On just like you are to take pictures then aim your remote to the camera press any of the button of the camera then you are suppose to see a light blinking. if there's no light check the battery or replace it with new ones..
Sep 23, 2013 | JBL New Original DCR600 Remote Control
My jbl pb 10 has a noise and it burn the fuse... changing the fuse it burn the fuse again..so it might have som other defective part that is causin the noise and the fuse burning... any sugestion?
It blows the fuse because a semiconductor device has developed a short (in otherwords acting like it was just a piece of wire). Because of the noise I would suspect the main amp device is the cause. It will be most likely on a heatsink.
Feb 06, 2010 | JBL PB10 Subwoofer
Jbl eon15p-1 my speaker it was working fine after 30 minuts wont turn on
Mine has a blown power supply transformer. There are 2 fuses on the power input board. One of the fuses on mine blows instantly because the primary on the tranformer has gone short cct. A $200 part from Jands !!!
Jan 07, 2009 | JBL Eon15P-1 Main / Stereo Speaker
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
Jun 27, 2008 | JBL PSW-D112 Speaker
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
24 people viewed this question
 Grubhead
Grubhead
