Question about Whirlpool LSR5132PQ Top Load Washer
Washer won't agitate or spin
My washer (model # LSC8244BQ1) will fill up with water and will drain but it won't agitate or spin. We just put in a new lid switch so we know that works. Help!
  • debbh5 Oct 23, 2008
    Thanks Krazykenny, now can someone tell me how to change the motor coupler??
I would say the problem is more than likely it is a broken motor coupler.it is the piece between the motor and transmission. they are cheap less than $15 and not to hard to change.any appliance parts store should have them..
Posted on Oct 23, 2008
  • kenny sulfridge
    kenny sulfridge Oct 24, 2008
    1st you need to take the cabinet off,there is 2 screws in the back of the cabinet,up by the top in at an angle. removed them and pull the console to you a little and tilt it over backwards.unplug the wire from the top of the console,usually gray,green and white, then pop the gold clips out using a screwdriver,open the lid and tilt the cabinet forward towards you and take the whole cabinet off. find the pump it usually white and remove the clips and bend it back out of your way,no need to take the hoses off. remove the 2 screws that hold the motor clips on and remove the clips.pull the motor off and there is the coupler,pry the old pieces off and install the new pieces.`1 on the transmission and 1 on the motor,just drive them on til the shafts are flush with the plastic, align them with the black rubber piece while you reinstall the motor.then installed the cabinet and console. dont forget to hook the wires back up....and you should have it.....
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
GE washer model WJRE5550K2WW - will fill water and drain but does not agitate and spin.
It new to me I am working on a GE washer model wjre5550k2ww it fill but not washing I can put it into the spin and it release the water but do not spin
Jan 05, 2011 | Washing Machines
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
