Question about JVC Audio Players & Recorders
I want cable which connects dvd (Model XV-THA9) to sub woofer JVC model SP-PWA(
NEED CABLE FOR UNIT XV-THA9
Posted on May 26, 2013
SOURCE: JVC TH-M303
Well this is and isn't a fix. I don't know what the underlaying problem is that causes the Amp to shut down but I have come up with a way to stop it from doing so. What ever the problem is it is triggering a circut on the board called "Protect" which can be circumvented. You need to start by pulling out the amplifier unit from the subwoofer assembly. You will see that there are two circut boards at 90 degrees to each other that are connected by 3 sets of connectors. You need to remove the screws and wire that hold in the board attached to the bottom of the assembly. You can then pull it out disconnecting the connectors. The connector closest to the power trasformer is the one that we are concerned with. On the vertically oriented circut board you will find a small map of the connector identifying pin #5 as "Protect". Inside the portion of the connector attached to the bottom board that you pulled out, use a small set of needle nose pliers to break off pin #5. Then reassemble the amp and put the subwoofer back together. I used this solution and it has been working since. If you have reservations about breaking the pin out then try just bending it out of the way and partially reassembling the unit and powering it up. Once you see that it does indeed solve the problem you can break it out. Like I said, I don't know why it started to turn off spontaniously in the first place but this does fix the problem.
Posted on Sep 25, 2007
billynad
  • 51 Answers
SOURCE: Need service manual or schematic for SP PWA 10
http://www.fixya.com/support/p183860-jvc_th_a10_system/manual-17024/page-70
got there choose the right manuel for you i think you can download it you might need this software to read it www.adobe.com get adobe acrobat reader
Posted on Jan 18, 2008
  • 29 Answers
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
First, make sure it didn't get muted, or the remote's volume got turned way down. Next, it might be time to involve a technician who can check all the power supply voltages. Many of today's electronics have multiple voltage power supplys, 5 volts for logic, 12 volts for motors, and amplifiers usually have the biggest- maybe plus and minus 30 volts for a total of 60. There are hazardous voltages in there too, a switching power supply starts with over 300 volts. So don't lick it and see if your tongue tingles, that's only for 9 volt batteries.
Posted on Jan 29, 2008
sticky92505
  • 77 Answers
SOURCE: TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Ryan
Posted on Feb 18, 2009
SOURCE: JVC sp-pwm606
Hello, it,s very possible that it,s circuit protector built in to the sub (if it,s a self powered sub) gets to the point of overload and shuts off as a protection so that the speaker won,t get damaged and also so the internal amp tha,t pushing the speaker sound is also protected since theese amps all have heat buildup, their are two types of subwoofers ,They are the powered ones and the ones that are powered bt the surround amp ,The ones powered by the stereo surround amp/tuner tend to throw out less power to the sub and the ones that have internal power are mostly higher powered , Another thing you might want to check is your polarity to the speakers and also the omage , Most home theater system speakers are 8 ohm,s but their are speakers and amps that can be changed to 6 ohm,s ..so you might want to check the speaker rating also . Well hopefully you can use theese different methods to at least troubleshoot and discount the thing,s that are not the issues , Good luck and hope theese sugestions might help you , Sincerely Glenn
Posted on Mar 04, 2009
Can I hook a jvc powered sub woofer model number SP-PWM303 to a yamaha natural sound receiver?
powered subs need a line level input so if the yamaha has this then yes you can
Oct 08, 2014 | Audio Players & Recorders
What model sub woofer can replace JVC SP-PW100?
open corel, at top click on about- click on activate and enter code
Sep 09, 2014 | JVC SP-PW100 Subwoofer
Which model sub woofer can replace JVC SP-PW100?
The simplest thing would be a like-for-like replacement. Ebay or Craigslist would be good sources if the sub is out of production. There's one listed on Ebay UK for 39 sterilng. Item number 171423774447 - ends 16th Sept 2014
For new replacements the answer depends partly on how you connect and then partly on where you live. I'll deal with connections first...
The JVC has both high-level -speaker cable sockets- and low-level -phono/RCA- connections. Budget subs with both sets are getting rarer in the UK.
If you are connecting from an AV receiver with the low-level phono cable then the Tannoy SFX sub would do quite nicely. It's 99 sterilng at Richersounds.
For a sub with high and low level connections then the Wharfedale Diamond sub is about the cheapest in wide distribution. 170 sterilng at Tesco, 150 sterilng as an open box special at Superfi. Personally though, if I were considering spending 150+ on a sub I'd go the extra mile and plump for the BK Gemini at 215 sterilng direct from the manufacturer. You're getting 300+ sterilng performance because they cut out the middleman.
If you live in the US then there's a bit more choice. Have a look at Bestbuy. The Pioneer SW 8mk2 isn't bad at 159 dollars. There's the Theater Solutions SUB6F at 88 dollars if you just want cheap. Respected speakers brand Polk has the PSW 108 at 199 dollars
I am looking for the connector cord that goes from my sub woofer to the system itself its the XV-THC4 Cord. can you help me find one.
The part you are looking for is a DIN/System cable.
you can order one from jvc directly
http://store.jvc.com/product.asp?Model=6200044901
or search DIN/System cable in google, theres a few cheaper ones.
Feb 01, 2011 | JVC THC4 Home Theater System with 5-Disc...
We have JVC DVD Digital Cinema System Model TH-A9. We enjoy elethe set and have many hours per day playing with the DVD music as well as the movies. Suddenly, our powered sub-woofer Model SP-PWA9 fails to...
It sounds to me that the sub has blown a fuse. This could be caused by a faulty amp. Subwoofers are at the end of the day are just a mono amp. If the main amp in it shorts, it will blow the fuse.
A visual test might be all that is needed, plus your nose if it has fried the part!
Jun 11, 2017 | JVC TH-A9 System
My JVC SP-PWM508 no longer functions.
I am looking for the cable connecting the sub woofer and the main system(CD Player)
Mar 14, 2010 | JVC SP-PW100 Subwoofer
I HAVE JVC SURROUND SOUND SYSTEM MODEL SP-PWM 45,I HAVE LOST 8 PIN CONNETOR FROM MAIN AMP TO SUBWOOFER. WHERE CAN I PURCHASE THIS CONNECTOR THANKS
Here is a link to the system cable that I think that you are reffering to. The model number of the system you have is TH-M45
The model number you gave is for the sub-woofer only. This is the system cable that is required to connected between the sub-woofer and the main head unit with the DVD changer in it.
http://www.jvcservice.com/store/ProductDetail.asp?Part=QAM0381-001%20%20%20%20
If you can not click on the above link, just copy the entire link and paste it into the address bar of your interent browser.
Since this is the part you want and it is the cheapest place to purchase it, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free technical support.
Thanks,
Dave
Sep 12, 2008 | Pioneer 1000 Watt 5.1 Surround Sound...
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
273 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
