Question about APW Wyott Kitchen Appliances - Others
Replacement part for popcorn machine
Chromalox disc heater 120 V 1000 W 6 inch 241-054265 009
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
What kind of lightbulb goes into my great northern popcorn machine
Does it have a bulb in it now? Try an appliance bulb you put in your over. They are around 40 watts. It may work if it has the correct socket.
May 09, 2014 | Great Northern Popcorn Roosevelt Eight...
Logic RSH-010910-018
You did not say where you live, so here in the city, we buy such stuff at any of the following places. A plumbing supply store, a hardware store, an appliance parts sales store, a lumber yard like Lowes, Home Depot, Menard's, etc., a Sears store, or if that doesn't help, try online, like at e-bay.
Be blessed.
Jan 07, 2014 | Element Chromalox SG1207 430086 Electric...
I have 2003 model whiz bang popcorn machine that takes forever to pop the corn
Old popcorn is the first thing to check, and that you are measuring correctly. 12oz of popcorn is the correct amount in a 3 min popping cycle. always time the 2nd batch.
That model popper has 2 heat elements, and 2 thermo stats that control them. If the first 2 things to check are good, then you dropped a thermo stat or heater and it is operating on 1 heater instead of 2.
Jan 21, 2013 | Gold Medal 2003 Whiz Bang Popcorn Maker
Old Fashion Movie Time popcorn maker
make sure the plug that goes to the heater is in properly. is it heating up?
Mar 15, 2012 | Helman Group Nostalgia CCP-515 Popcorn...
How to tell which element is bad in a hot water heather , when the heather have two element.
if you have a multi-meter you can remove the cover plate and check for current flow through the element.
Aug 06, 2011 | Element Chromalox SG1207 430086 Electric...
My 1987 model HAF-315D Cromolox forced air Electric furnace will not stop, what are the things to look for..
Bad thermostat, stuck relay Bad limit switches. Have a diagram handy and trace the components and test with a volt/ohm meter
Oct 06, 2010 | Element Chromalox SG1453-430334 Electric...
Elite Cuisine EPM 400 popcorn machine
Maximatic Deluxe Popcorn Trolley Elite Cuisine EPM 400 popcorn machine burner is burnt out. where can i find a replacement pot?
Jul 23, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
Hot Water Heater runs too hot
Here is the website for ThermoDisc. It looks like the 59T thermostat is still available. http://www.thermodisc.com/productdetail.asp?ProductID=84. On a positive note, the PT valve (pressure/temperature relief valve) is supposed to pop off before the tank blows up. An electric water heater rarely lasts more than about 11 years under good conditions, so I think it would be wise to weigh the possibility of replacing the water heater. Newer ones have much better insulation which should save you in operating costs over the long run. In addition, if you fix it now, then something else goes bad, and it will, you will probably conclude replacement would have been the better option.
Mar 16, 2009 | Element Chromalox SG1353-430326 Electric...
Kitchen Appliances - Others Logo
74 people viewed this question
Top APW Wyott Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an APW Wyott Kitchen Appliances - Other Expert? Answer questions, earn points and help others
