Question about Canon imagePROGRAF iPF650 largeformat colour inkjet InkJet Plotter Printer
Error 03800500-2f47 Flashing Hardware Error message
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
My sony camera DSC-W320 has an error message E:91:01 error message flashing and flash don't work
Flash capacitor in the camera did not charge in specified time. You can try to initialize your camera and wait if it will charge - if problem persists, there is hardware damage and it will have to be repaired by technician (do not try repair it by yourself - high voltage!)
May 18, 2011 | Cameras
My xbox is got a e74 system error what is it an can i repair it
It's a known failure on the XBOX 360 and Microsoft will cover it even after the device has gone out of warranty.
Excerpt from About the E74 Error:
...the E74 error message can indicate the general hardware failure that is associated with three flashing red lights error on the console. As a result, we have decided to cover repairs related to the E74 error message under our three-year warranty program for certain general hardware failures that was announced in July 2007. We have already made improvements to the console that will reduce the likelihood of an occurrence of this issue. Detailed information related to the Xbox 360 warranty and resources for those who require repair can be found at http://www.xbox.com/support (http://www.xbox.com/support) .
Apr 29, 2010 | Microsoft Xbox 360 Console
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Xbox 360
E74 error message can indicate the general hardware failure that is associated with three flashing red lights error on the console. As a result, we have decided to cover repairs related to the E74 error message under our three-year warranty program for certain general hardware failures that was announced in July 2007. We have already made improvements to the console that will reduce the likelihood of an occurrence of this issue. Detailed information related to the Xbox 360 warranty and resources for those who require repair can be found at www.xbox.com/support (www.xbox.com/support) .
Microsoft will refund to customers the amount paid for an Out of Warranty repair due to a general hardware failure associated with the E74 error message. Those customers should automatically receive the refund within 4-12 weeks, and no additional action by customers should be necessary. Customers can choose to receive either a refund to their credit card or a check refund. Checks should be received no later than the end of July. If you have any question regarding refund status, contact Xbox Customer Support at: http://www.xbox.com/support/contact .
you can submit a console-repair request online by using the links in the "Additional support" section. To confirm your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
uparrow.gifBack to the top Additional support loadTOCNode(2, 'moreinformation'); If your console continues to display the E74 error message, it requires a repair. For more information about how to start the online repair process, please visit the appropriate Web site: Inside the United States
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair)
Outside the United States http://www.xbox.com/support/ (http://www.xbox.com/support/) Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Sep 29, 2009 | Computers & Internet
My xbox 360 has error 74
The E74 malfunction is a problem believed to be associated with the system's video output cables and/or hardware scaler chip. The problem involves unusual screen patterns, the appearance of an on-screen error message, and finally a flashing red light in the lower right quadrant of the power ring. When a system suffers from the failure the on-screen message reads "E74 System Error. Contact Xbox Customer Support."
You could send it in to Microsoft of you can follow the steps as outlined in this You Tube video.
Mar 21, 2009 | Microsoft Xbox 360 Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
One flashing red light on power on circle
Hey steph 1,
According to information provided by the manufacturer, you may see one flashing red light on your Xbox console if there has been some kind of hardware failure. This failure may have occurred in the console itself or an external accessory, so it's recommended that you disconnect all accessories - including your controllers, hard drive and memory units - then restart the console to see if the problem persists. If disconnecting all of these external devices resolves the problem, then the hardware failure is with one of those accessories.
Please keep in mind that this only applies if there was no error message accompanying the flashing red light. If a numbered error message also appears, you may wish to refer to Microsoft's online support database for more information:
There you should be able to find links to pages with troubleshooting steps you can take for the most frequently encountered error messages. Additionally, remember that you can always contact Microsoft directly at their toll-free hotline for further assistance: 800-4-MY-XBOX (800-469-9269).
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | Video Game Consoles & Games
1 redlight flashes clearly red at bottom right hand side of the power ring,and 2 other dim red lights are flashing,only the 1 in the bottom right is bright though.it happened 2weeks ago but i tryed it...
Do you get an error message on your tv screen? 1 flashing red light means there is a hardware failure such as your DVD drive hard drive, dashboard error ect. Not much can be done about this issue besides having microsoft fix it.
Apr 23, 2008 | Video Game Consoles & Games
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Canon imagePROGRAF iPF650  largeformat  colour  inkjet InkJet Plotter Printer Logo
994 people viewed this question
old marine
old marine
