Question about Seagate (ST380011A) 80 GB IDE Hard Drive
I recently cloned a 18gb hard drive disk onto my new 80gb disk. Now it says on the local disk (C:) that the total size is 18gb. Whats happened? = /
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    cloned another drive, did that include the operating system from that other drive?
  • 849 Answers
For cloning there must be same size drives
Posted on Oct 24, 2008
Hello I have a Compaq Presario v5000 laptop and my 80GB 2.5" IDE internal hard drive is failing. I would like to buy a new hard drive, say 200GB 2.5" IDE for my laptop will the new hard drive...
There are two types of 2.5-inch disk-drives: those with the (older) "parallel-ATA" interface, and those with the (newer) "serial-ATA" interface.
The easiest way to determine what you have is to take the laptop with you to the computer-store; they can inspect your current disk-drive, and sell you a compatible replacement.
A "good" computer-store can "clone" your existing disk-drive onto the new disk-drive,
copying all the files (your files and the Windows files), and then you can restart and resume
normal operation.
Given the "vintage" of your computer, my guess is "parallel-ATA".
Dec 16, 2010 | Computers & Internet
Medion MIM2080 MD95408 Original 40gb hard drive has died. Purchased 80gb replacement. Have cloned WIN_XP_PRO from another device onto new hard drive. When laptop boots all you get is a black screen...
did you get all the files? most likely there is a corrupt or missing set of files in the cloned files
i suggest you either get a new hard copy (disks) and install from there or use linux (most linux OS's are free online)
Nov 16, 2010 | Computers & Internet
Im trying to upgrade my hard drive from a 40g to a 160 but it only shows up as 40gb
You probably used software to "clone" the "old" disk-drive to the "new" disk-drive. So, the "new" drive is an *EXACT* image of the 40GB drive.
Click Start
Point to My Computer
Click with the SECOND (usually the RIGHT) mouse-button.
Click Manage
Double-click Storage
Double-click Disk Management (local)
You'll see that the "last" 120GB on the new disk are "unallocated".
Use that "disk-cloning" software to "resize" the 40GB partition on the new disk-drive, to integrate that "unallocated" space into the current partition.
Or, right-mouse click on that "unallocated" space, and create a partition within that space, and to "format" that space, and to assign a drive-letter (E: ? F: ?) to that 120GB of disk-space.
Nov 11, 2009 | Dell Dimension 3000® Pentium® 4...
Laptop should have 80gb of hard drive but only shows 62gb
The rest of size might have been used for system file ..you can see it by
goto > tools>folder option >uncheck hide system file ...
Jul 18, 2009 | Computers & Internet
Hard drive help
What tool did you use to clone the drive? During the cloning process, it almost always gives you the option to resize the destiniation partition, but by default, it leaves the destination partition the same as the source. If you go into Disk Management on your computer, do you see the other 270GB as unpartitioned space? If so, you have two options - you can create a new partition and move your data onto it - or you can re-clone your old drive and make sure to expand the destination partition if given the option.
May 17, 2009 | Dell Inspiron 6400 Notebook
Thinkpad T42 Hard Disk problem
Hello.
It seems the hard disk size will max out at 80GB with a 5,400 RPM speed according to IBM.
Im sorry to say that this means that it will not support a 120Gb hard drive.
Regards...
/Tech5508
Feb 14, 2009 | IBM ThinkPad T42 Notebook
Harddrive problems
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
Internal 80gb harddrive excelstor j880
Using as startup disk
If you used Acronis, you need to clone the 30Gb and not backup. In doing so, the booting information is likewise copied to the 80Gb, whereas back up is simply copying contents (that you specified) hence will not boot and not be active.
Pls remember that by cloning, Acronis would erase the partition (and contents) of the 80Gb. At certain settings, it would also split the 80Gb into 2 partitions; 30Gb & 50Gb. Further, verify that the 80Gb is "Set Active" and partitioned as a Primary and not Logical.
As to your other concern of installing, in some instances, some not so recent motherboards' BIOS/CMOS will not recognize the 80Gb. Other than that, you were doing it correct; new 80Gb as primary/master with jumper to the pins nearest the IDE cable, any other device (CD ROM or another HD) should be set as primary/slave (SL). Additionally, pls verify that your motherboard auto-detected your new 80Gb as your primary boot media (settings in your CMOS/BIOS).
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 03, 2007 | Samsung (SP0822N) 80 GB Hard Drive
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
65 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
