Question about Panasonic Microwave Ovens
How to change bulb in Panasonic NNA883W combination microwave without calling out engineer
Bulb needs replacing but manual states engineer must be called out. Is it possible to change it without calling out engineer?
MicrowaveSvc
  • 9047 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Replace light bulb on Whirlpool GMC305PDS07
You'll need to remove the outer cover (wrapper) to get to the bulb.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
najah
  • 180 Answers
SOURCE: Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
Posted on May 26, 2009
SOURCE: panasonic genius microwave light bulb
Hi all, I have just replaced the bulb in my Panasonic NNA873 Dimension 4. Please be careful,although it was an easy job, there is a capacitor inside which stores heavy loads of power and will release the electricity into you if you touch it! YOU CANNOT REPLACE THE BULB FROM INSIDE THE MICROWAVE....... DO NOT REMOVE THE CARDBOARD-STYLE COVERING WHICH IS ATTACHED WITH ONE SCREW INSIDE THE MICROWAVE ON THE RIGHT. To replace bulb will take 5 minutes. UNPLUG microwave. Remove the outer cover by unscrewing about 6 screws (ordinary phillips) don't lose them into the workings....... Bulb is located on the right side, nearer to the front. You cannot see the glass of the bulb, only the black plastic end piece, as the bulb sits upside down and vertically. Best if you check out what a T170 looks like on the internet, then you will know what you are looking for. For my Panasonic I needed a T170 (but be careful, they have different ends, some are straight, some right angled - mine was right angled - check before you buy and no, I don't think you can get them from any ordinary supermarket etc!!). Do not touch the bulb when replacing as the oil on your fingers will shorten its life. Old bulb can be removed by taking out one screw and then pulling off the connectors - there is a little tab to push down to ease them off. Then simply replace bulb! When putting cover back on make sure all the tabs on top and sides go inside not outside casing. Good luck. This is an easy job, just don't poke around anywhere else.
Posted on Jun 12, 2009
SOURCE: Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
Posted on Aug 27, 2009
Testimonial: "Hi - and thanks Martin for an excellent description of the process. Perfect assistance for a handyman-challenged guy like me. Thanks Grant"
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
I have a whirlpool combination microwave with oven. How do I change the bulb in the microwave?
Whirlpool Microwave Bulb Replacment - YouTube
? 4:35
https://www.youtube.com/watch?v=RQM302PShKw
Oct 29, 2011 - Uploaded by Dan Jiles
I show how to access the bulb on a Whirlpool Microwave that shines on your cook top, as well as how to access and replacethe bulb that is for the microwave ... ... How to disassemblemicrowave oven. Find info: fuse, bulb, fan ..
Nov 07, 2015 | Whirlpool Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Panasonic Model #NN7524A Microwave bulb replacement help
microwave---NN-S335 , 800W Plate exploded , Where can I get another ? From C Carver Feb. 23 , 2009 Thanks
Feb 25, 2009 | Panasonic Microwave Ovens
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
I have a panasonic microwave, model NN-GD566M. The bulb has gone but the microwave still functions ok, I cannot find the instruction manual and need to purchase the part, Can you help. I need the part...
You can find the instructions for this model here and here.
You should be able to find generic replacement bulbs from local appliance parts stores, home improvement stores, or via a local Panasonic-authorized servicer you can locate here.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 26, 2008 | Microwave Ovens
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Panasonic NN-H664 1200 Watts Microwave
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job.
It's really helpful if you have your original installation instructions to do this.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Panasonic NN-H664 Microwave Oven
Need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at http://www.wehaveparts.com or Vance Baldwin at http://www.vancebaldwin.com You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Dec 13, 2006 | Panasonic NN-2505A Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
