Question about Maxtor Hard Drive
Diamond max 20 hard drive won't install - jumper problems - want as slave, my old one as master
Don't know how to set pin. Want it to be slave drive. Not specific instructions, only on master & ata cable.
  • 903 Answers
On the back of the drive there should be a black, white or yellow jumper. If you look very carfully at the back of the harddrive where the jumper is, it will tell you which position you need to have the jumper in for slave and which position you need to have it in for master. If it is already in the master position, carefully pull it out then push it back into the correct position to act as slave. Some hardrives simpley have a M for master and a S for slave while other harddrive will actually have the words. I hope this helps.
Posted on Oct 23, 2008
I have a maxtor 51536h3 harddrive, I need to know the jumper settings for running single as a master and slave to transfer the data to another harddrive. THANKS
If you have two hard drives on the same IDE cable, then set one as Master and the other as slave.Set which ever one has your operating system on it as the master (though it doesn't really matter). Once you get them both plugged in and your computer boots up. You should see both drives and can transfer data as you see fit.
Mar 03, 2011 | Computers & Internet
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Install old maxtor HD on newer pc, change it from mster to slave
From your own description Slave : Off therefore remove the jumpers
Jul 26, 2009 | Computers & Internet
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Fixed slave/master settings, installed, but
hi patnelligan
check inside your system BIOS (cmos settings) and look for plug and play OS setting, make sure this is set to Yes also you could try setting the jumper on your slave drive to cable select
hope this helps
Oct 25, 2008 | Maxtor Hard Drive
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Video and photo files
Dear Friend,
Point your browser to
http://stason.org/TULARC/pc/hard-drives-hdd/maxtor/87000D8-DIAMOND-MAX-7000MB-3-5-SL-ATA3.html
or
for more drives to
Alternatively
JumpersMAXTOR DIAMOND MAX INSTALLATION SHEET
Jumper Setting
+---+---+---+---+---+ |J50|J48|J46|J44|J42| +-------------------------------------+---+---+---+---+---+ | Master/Slave | | | | | | | Only Drive in single drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Master in a dual drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Slave in a dual drive system | O | | | | | +-------------------------------------+---+---+---+---+---+ | Cable Select | | | | | | | Disabled* | | O | | | | +-------------------------------------+---+---+---+---+---+ | Enabled | | J | | | | +-------------------------------------+---+---+---+---+---+ J=Jumpered O=Open *=Default
Feb 05, 2008 | Computers & Internet
Maxtor Hard Drive Logo
97 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
