Question about Sharp Office Equipment & Supplies
Error code: H 4 flashes.. Nothing works
That's basically it! The copier does NOT work and the characters H 4 flash alternately.
  • sam gerban
    sam gerban May 11, 2010
    make and model?
  • Mike S
    Mike S May 11, 2010
    WHat model is this? there should be two more Characters such as H4-00
    If you have an LED displaying H4 hold down the green button for a sec and if 00 flashes behind the H4 then you have a fuser unit problem..
    You can try to Clear the display of self-diagnostics with SIM 14
    Heat roller abnormally low temperature
    The setup temperature (about 90°C is not
    reached within the specified time (about
    35sec) from turning on the power ON SW.
    (When the temperature falls below 120°C
    in the standby mode.)
    Thermistor defect
    Heater lamp failure
    Thermostat failure
    Check the heater lamp blinking with SIM 5-2.
    When the lamp blinks normally:
    Check the thermistor and the harness.
    Sniper:
  • 87 Answers
H4 PRESS START KEY THERE WILL BI A SUB CODE LIKE 00.THAT IS HEATER UNIT TEMPERATURE PROBLEM.RESET IT BY THIS PROCEDURE.
PRESS CLEAR KEY,AUTO PHOTO MODE KEY,CLEAR ,AUTO PHOTO ,
COPIER DISPLAY DEAD 14 START KEY.
PROBLEM REMOVES
BY MIAN JEE
Posted on Dec 18, 2008
My copier is displaying flashing 4 and H
press the start button (big green button) , to see the next part of the error code ,
a simple reset should be able to fix this , so depending on your copier model, and the rest of your code ..........
Aug 21, 2014 | Office Equipment & Supplies
Estudio3500 spanner flashing call service, how do you find what the error code is
When your copier is displaying an error the code will be found in the top right hand corner of the display. It will be a mixture of letters and numbers and will be 4 characters. If the copier is not displaying an error code, holding the c and 8 button will make it appear.
Sep 24, 2010 | Toshiba E-Studio 3511 Color Copier
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Oki 5521 alarm light flashing. No other lights flashing. Nothing in manual.
    You have a fatal error, what kind of error is specified by led combination of PRINT QUALITY and CHARACTER PITCH.
    Oct 07, 2008 | OKI Office Equipment & Supplies
    Epson C48 red and green lights flashing alternately
    Only Solution is Re-burn printer firmware.
    Mahesh DG, Pune
    Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
    CANON PIXMA MP180
    I had with canon printer the same as yours, just press the restart button at least 5 seconds and it will print
    Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    My Canon Pixma MP170 printer is showing error code 5800, What must i do to fix this?.
    MP170 (5b00) Ink Tank Full Error Reset
    1,power off.
    2,hold stop/reset ,hold ON/OFF
    2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
    3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
    4,then push power twice, quickly
    5,power off and power on.
    Jul 15, 2008 | Office Equipment & Supplies
    I had the error message L-4 .can you halp to fix this problem?
    L6 is a laser polygon motor fault, you need to replace the polygon motor in the laser unit, but try the reset code first sim 14
    May 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
    Error code 5010
    Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
    I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
    I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
    Sooooo irritating!!!!!
    Anyone know what to do?
    I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
    Mar 24, 2008 | Canon PIXMA MP510 All-In-One InkJet...
    298 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
