Xerox workcentre pro 265 error 14-563
Error 14-563
5 Suggested Answers
  • 208 Answers
SOURCE: Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Posted on Nov 28, 2007
  • 2072 Answers
SOURCE: Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Posted on Feb 18, 2008
    • 3 Answers
    SOURCE: Xerox WC Pro 35 - Error 14-563
    this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
    Posted on Oct 07, 2008
    • 2072 Answers
    SOURCE: workcentre c2424 is showing system error 39,003.40:117010
    That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
    If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
    Posted on Oct 23, 2008
    My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
    my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
    Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
    Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
    Try this link, it goes directly to the 64 bit driver download site.
    http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
    If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
    You will find 32, 64 bit drivers for all OS.
    Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
    Xerox wc pro 423 u2-3 problem
    my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
    Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
    Error 116-364
    Error 116-364 Problem with the Xerox WorkCentre Pro 123/128 Copier Finisher Staple Refills Copier. Dear i am also facing the same problem, It would be very helpful if you share the solution you may had come across. Thank you very much .
    May 17, 2010 | Xerox WorkCentre Pro 123/128 Copier...
    H2 Blinking on the panel
    Error code means that:
    H2 Thermistor Open
    Part #
    Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
    Mfr Part #: RDTCT0128FCZZ
    Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
    Xerox Workcentre Pro 123 error code 016-719
    this is not a mechanical error but a software error.
    It either doesn't recognise the format or program
    as for the driver don't thinkit's the problem the HP can use PCL6
    Sep 08, 2008 | Office Equipment & Supplies
    Xerox printer and windows vista
    use workcentre pro 265 drivers. worked fine for me and is embedded w/ the vista os.
    Mar 27, 2008 | Office Equipment & Supplies
    67 people viewed this question
    k24674
    jasbo
    jasbo
