Question about AEG Ovens
I have an aeg b8100 competence oven and there is an F9 on the display. what is the meaning of this?
I want to fix the fault on my own if its possible. The instruction manuual i have doesn't mention any troubleshooting table with the fault codes. The problem is that an F9 appeared on the display.
Gigatech
  • 259 Answers
SOURCE: monogram wall oven F9 error
“F— AND A NUMBER • You have a function error code. Press the CLEAR/OFF pad. Allow the OR LETTER” FLASH oven to cool for one hour. Put the oven back into operation. IN THE LOWER OVEN • If the function code repeats, disconnect all power to the oven for at DISPLAY least 30 seconds and then reconnect power. If the function error code repeats, call for service Here is someone that had the exact same problem: intermittent F7 error code. I couldn't even get it to do the F7 error . There's a pretty good tech service sheet inside the control panel. I followed its procedure for testing the keypad (which was nothing more than pressing all the buttons and hearing it go "BEEP!" silly.gif). But the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved! It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here. **** this helps. :]
Posted on Dec 14, 2007
  • 14 Answers
SOURCE: F9 code on stove
There should be some number after the F 9 Error code. And, it would look like this F9-1 Latch lock upper F9-2 Latch unlock upper F9-3 Latch lock lower F9-5 Latch unlock lower F9-6 Latch both lower This is just to give you an idea. But one thing you can try is UNPLUG THE UNIT AND LEAVE IT LIKE THAT FOR AN HOUR OR TWO, AND THEN PLUG IT BACK ON.
Posted on Jan 23, 2008
  • 1462 Answers
SOURCE: clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Posted on Jul 14, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
fixyourboard
  • 310 Answers
SOURCE: frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Posted on Jul 25, 2009
The display erratically flashes 12:00 and cannot be set. I have the manual. Everything else seems fine. Timer just resets back to blinking 12:00.
Call an AEG repairman .would be my choice of repair.but FIXYA does not have a photo you provided us .
Dec 13, 2015 | AEG Ovens
AEG competence B4101-4 built-in electric oven, the fan is staying on continually even when not in use. Only goes off if the oven is switched off at the mains. Is there a way to fix this problem?
when i bake a chocolate sponge cake it rises well,when cooking the top becomes cracked like dry earth and when switched off it comes down about a third. with my previous oven baking thesame recipee for 30 years i never had a problem- please advise the reason for this problem
May 26, 2011 | AEG B4101-4 Electric Single Oven
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Heat element is not coming on!
It is entirely possible that while cleaning the oven you may have inadvertantly bumped the element enough to cause it's connection to come loose enough not to work. With the power unplugged, wiggle the element where the connection is made inside the oven. If this does not work it is possible the element has 'gone bad'. Sometimes this happens from various causes and replacements are available from the manufacturer
Dec 04, 2009 | AEG Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Sep 22, 2008 | AEG B2100-4 Electric Single Oven
AEG Oven
Probably there is an electrical relay that has failed.. or if electronically controlled, the equivalent circuitry. Or maybe a thermostat has failed. Be careful with anything electrical, as these kinds of faults may need a trained tradesperson. They can be dangerous to play with, as you need to be able to take electrical measurements and use tools to repair this yourself.
Apr 27, 2008 | Ovens
Ovens Logo
211 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
