Question about Frigidaire GLTR1670A Front Load Washer
How to remove the dispenser tray on a frigidaire gallery front load?
the dr
  • 447 Answers
SOURCE: error code
what is the code???
Posted on Jan 05, 2008
  • 220 Answers
SOURCE: fabric softener dispenser won't drain the fabric softener.
Not sure if you already did this, but try pulling the face plates off inside the dispencer and take it to the sink and run very hot water into the "stand pipe" that projects off the back of the face plate to make sure they are clear and no old crusty products are in the hole.. Then put them back in and push down hard and make sure they are fully seated.
If the plates are loose and not seated or clogged, there will be little or no siphon effect to draw the fluids out of the dispenser. At least thats how it seems to work
Also, if you pull the top off the washer, there is an adjustment on top of the dispenser to adjust the dispensing ratios I believe.
I just did that procedure the other day on my machine and the wife said it works good now.
Let me know it it works for you, I was wondering if it was just a coincidence.
Posted on Jan 16, 2009
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Posted on Apr 15, 2009
venexcsd
  • 1185 Answers
SOURCE: i have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
Posted on May 23, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
Ice Dispensing Paddle is Broken
Not sure about the frigidaire,but most front panels can be removed from front. If you look around outer edge of trim piece there might be little screwdriver slot. Carefully pry off trim piece(faceplate),disconnect electrical plug on back,set aside.Once removed you should see you solution for removing paddle.
Jul 23, 2013 | Frigidaire Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a frigidaire gallery front load washing machine that I purchased about 4-6 years ago. The softner will not dispense. I have taken the entire dispense unit out and have run hot water over it to try...
Add white vinegar to the dispenser and run a load. If that does not solve the problem take the dispenser out and soak it in a 50:50 white vinegar and water mixture for an hour
Sep 24, 2017 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
We have a Frigidaire Gallery 16 cycle Front loading clothes washer purchased in 2002 and it is leaving what looks like grease streaks and stains on some clothes. We have washed only with Cold water. any...
I removed the drawer for detergent and bleach dispensing and it was
quite dirty form build up of dirt and detergent.
than ran hot water cycles and it seemed to fix.
Oct 14, 2009 | Frigidaire Washing Machines
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Soap dispenser keeps filling with water after everyload. I have to empty after load. The dispenser is also growing mold.
You should clean the soap dispenser regularly by removing it from the washer.
Some units have a release clip but some just need to be pulled out firmly by hand.
Then give the tray a very good clean as no soap residue should be present. It sounds like the fabric conditioner cycle is filling the relevant tray section but unable to drain through blockage.
Should be pretty straight forward to remedy.
My regards
Marc
Apr 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTR1670A Front Load Washer Logo
156 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
