Question about Precor C954i Commercial Treadmill
Belt slipping on precor 954i treadmill - Precor C954i Commercial Treadmill
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
SOURCE: c956 precor treadmill
Hi
not to sound funny but are you sure that you have this tread set in the units (mpg/kph) that you require. i have worked in loads of gyms and its a common problem that people think the belt is running to fast because its set in kph and that thinks its in miles eg 9mph = 14.5kph
you can check and change the units in the club setting menu.
hope this helps :)
Posted on Feb 12, 2010
  • 95 Answers
SOURCE: Where can I buy a replacement walking belt for a
FitnessRepairParts.com has a walking belt for Precor 9.21 treadmill (it says it is used on four different versions of the 9.21... make sure your specific model number is listed)
Posted on Feb 21, 2011
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
Posted on Mar 06, 2011
ercupa190
  • 12223 Answers
SOURCE: Precor 954i the stop button is stuck
try to tight the RIbbon CAble inside for keypads, and tight the upper cable vs lower cable.
2) Adjust the REED swtich, test it, clean it, see the diagram, and tight very well the plug-
God bless you
Posted on Nov 29, 2012
My treadmill precor 954i showing stuck key. So what solution for this problem???
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is normally caused by a stuck key on your keypad. To resolve this issue, you must replace the keypad.
The following link may help, but you will need your serial number to find the correct item.
Repair Parts for Precor C954i Treadmills 120VAC 240VAC SPORTSMITH net
Nov 13, 2015 | Precor Exercise & Fitness
I recently bought a used Precor 954i it worked fine then when i brought it home and wired it in with a 20amp breaker and 240 volt im getting error 29 as soon as i turn the machine on any ideas?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29 Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Sep 22, 2015 | Precor 954i Experience Series Treadmill...
954i will not power up
Verify voltage to the MCB. If it gets power, and 2 MCBs do not light up the console, check the wiring to the console. If that looks good then it sounds like you need an upper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Apr 03, 2014 | Precor 954i Experence Series Treadmill...
Belt slipping
This is a common issue. Over time the belt stretches. You will need to adjust the tension on the running belt to alleviate this issue. If there is no adjustment room left, then you will need to replace your running belt and deck surface. The link below will take you to the products for your machine. Please use your serial number to narrow down your choices.
Precor Repair Parts for 9 27 Treadmills Consumer SPORTSMITH net
Jan 04, 2014 | Precor 9.27 Treadmill
The belt is slipping
Error 29 message coming up on screen
see the error code and fix it. God bless you
Error 29, Excessive AC Input Current, this mean that some elements inside of the treadmills is consuming more AC currente, like transformer, main motor.
see the block diagram attached.
Nov 28, 2012 | Precor 954i Treadmill Refurbished. 115...
God bless you
Nov 15, 2012 | Precor Exercise & Fitness
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Apr 16, 2011 | Precor C956i Treadmills with HR /...
Belts are slipping,
hi,
your treadmill's belt is loose. You have to tight the belt from the both side.
all the treadmills follow the same procedure for tightening the waking belt. Watch the following video for the same.
ok
Mar 16, 2011 | Precor 956i Experience Series Treadmill...
Precor C954i Commercial Treadmill Logo
48 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
