Question about Ricoh Office Equipment & Supplies
Light streaks on paper with Ricoh cp431dn
Prints a light streak down the one side of the paper. How can I fix this?
SOURCE: Color Streaks down length of page
This is a laser printer, neither a copier nor a multifunction unit, therefore it has no glass. At least, I cannot find any glass in it.
I finally had an authorized Ricoh repair center examine it and found streaks on the black unit that pulls out of the right side (I forget the part's name, <$90). We replaced it and things are better but streaks of color remain. They suggested replacing the color one (about $400) but the cost is prohibitive right now, so I'll live with those streaks.
On a related note, I remain unimpressed with this printer's quality and inconsistency. For example, greys often print in pink; nothing has ever resolved this. I refuse to put any more money into it. When I can afford to do so, it will be replaced, probably by a Xerox Phaser.
Posted on Feb 28, 2008
  • 3 Answers
SOURCE: 2 IN. GRAY AREA DOWN SIDE PAPER
I too began to have vertical grey streaks on output from my trusty LaserJet 4 Plus. If I printed a page from text pad with just a single period on it the streaks were there, varying shades of gray in varying widths from 1/4 inch to 2 inches. I noticed the transfer roller was soiled in a way that matched the streaks and so was the green colored drum in the toner cartridge. I cleaned the toner cartridge and transfer roller and that completely solved the problem. 1. Cleaned transfer roller with old clean white dry t-shirt. Kept gently wiping toner off until it seemed pretty clean. Find info on web about how to remove the transfer roller in the service manual.
Get service manual by searching for LaserJet 4 on this web site:
http://www.eserviceinfo.com/
(you have to download it in several parts as .rar files, put all the rar files in one folder and then open the first .rar file with a program like Power Archiver and it will add all the files together into one big PDF file of the service manual) 2. Cleaned the half of the toner cartridge that houses the green drum roller. I followed the steps in Part 1 on this web page:
http://www.oddparts.com/ink/hp-4.htm 2A. I removed the green drum and wiped that off with old cotton t-shirt then set it aside out of the light. 2B. I cleaned the little roller (PCR roller) mounted behind the green drum, inside the toner cartridge with a slightly damp piece of cotton t-shirt, rubbed gently for quite a while to get to the white underneath the old toner. Did not get all of the toner off. Did not submerse this roller, just used slightly damp cloth. 2C. Detached the piece of metal that keeps old toner trapped in a compartment and also gently wiped toner off the plastic blade on it that is called the wiper blade. 2D. I scooped out old toner and then vacuumed out the rest from behind the metal piece described in 2C. Reassembled and no more streaks, totally clean page output.
Posted on Mar 01, 2009
  • 9 Answers
SOURCE: WHITE STREAK SOWN LEFT SIDE OF PAPER RICOH CL3500
I will try to explain what is happening here. Basically, the PCU's are what puts the toner to the paper. As the parts spin, if there is clumped up toner in there, you will get the "light" streaks on your print out and the streaks will run the entire length of the page for that 1 color (or black). If this is your problem, then here is what I do.
This is messy, get a plastic bag - preferable something you can see through.
Get a feel for where the opening slider is on the top of the PCU and slide it open and hold it open in the bag.
Turn the PCU upside down and shake out all of the loose toner, you will have to turn the unit "to and fro" while shaking and banging it lightly.
Sometimes this will free up the clump of toner that is built up in between the sides of the toner trap and the roller. There's 1 roller that is constantly "dipped" in toner and the other roller that pulls the toner that is needed off of the "dipped" roller to apply to the paper. The one that is "dipped" is having the toner rubbed off by a clump of toner prior to getting to the other roller therefore only transferring a reduced amount of toner where the buildup is.
I have also on the Black PCU have removed the top 2 screws, taken off the green end cap (watch for the 2 plastic plugs that will fall), flicked the spring clips off of both ends and removed the 1 gear to pull out the roller assembly inside the PCU and used a high pressure blower (or canned air) to clean out any clumps. I don't recommend this to anyone that is not mechanically inclined. You can try to blow out the unit through the small slider opening on the top, but you may not get to the part where the streak is.
Good luck. Be sure to rate this post if it helps.
Posted on Apr 06, 2009
SOURCE: clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Posted on Dec 02, 2009
LHeruska
  • 94 Answers
SOURCE: Printer streaks on card stock
adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Posted on Jan 30, 2010
Testimonial: "Thanks. It looks good but I'll need to study it."
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
Prints a light gray streak down the left side of paper
either the drum developer or fuser if you can show me a sample I can tell you which it is
Apr 14, 2014 | Kyocera Office Equipment & Supplies
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Ricoh 6513 streaking
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Mar 21, 2008 | Ricoh 6513 Copier
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
24 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
